2010 2011 BMW 5 Series Forum F10 Front brakes/discs replacement options |
09-14-2016, 08:21 AM | #23 |
Rep 54
Just had the car MOT-ed, it passed, not even an advisory.
New discs arrived in the post, so now they're ready for installation when needed. The car can't warn you when the discs are "too worn", right? Only for pads? Would someone mind explaining how the sensor works? Do we basically ignore the (woefully inaccurate and pretty much useless, at least in my own experience) iDrive, and wait for the warning to come up on the dash? Many thanks! |
09-14-2016, 10:57 AM | #24 |
Rep 144
Idrive is based on driving based calculations.
Brake pad light is contact based and will kill the sensor once activated. Meaning will need to replace the sensor once activated. It's set to activate once the pads wear to nothing. |
09-14-2016, 01:52 PM | #25 |
Rep 23
Pad sensors are fitted to the metal backing of the pads, they extend into the pad area so that when the pad has reached its minimum thickness the disc rubs the sensor and shorts out sending a signal to the cars warning system.
On many cars the sensor can be reused on new pads, being away from the disc prevents them shorting out, but its a suck and see situation, you can always test before putting the wheel back on and it only takes a few seconds to change to new ones if there is a problem. I have reused on previous cars without any problem. Some sensors just fit in by friction or springs, some cars they are actually part of the pad. http://www.pelicanparts.com/BMW/tech..._Pads/pic3.jpg |
09-14-2016, 02:45 PM | #26 | |
Rep 186
09-15-2016, 11:40 AM | #27 | |
Rep 2,072
This time when my 535d needed front brakes, I just paid full whack and let BMW do it. It's their problem if any issues arise (first plus point) but the issues are less likely to arise as the parts are all original (second plus point). |
J306TD18.50 |
09-26-2016, 07:11 AM | #28 | |
Rep 582
From new, the car counts down the pad life using a specific algorithm. I don't know whether this is linear, whether it uses fuel consumption to estimate driving style, or whatever. But it counts down. Once it reaches 2200 miles (Which is 3500km) it stops counting down and sits on 2200 miles without changing. It will sit here until the first stage wear sensor is triggered. It then resumes counting down, using the time taken from new to first sensor to calculate a more accurate remainder. At some point, it'll trigger the second stage wear sensor which pings up the brake pad light on the dash. Now of course I cannot 100% state that the above is true, however on my last F10 the rear pads stayed at 2200 for about 4000 miles and then continued counting down. I checked them at 1000 miles to go and they were ready to change. We also have a Mini Cooper - it too has been sitting on 2200 miles to go for months and months now and there is plenty of life left so it's presumably waiting for the first sensor before resuming countdown. Hope this is of use! FWIW I got to 45k on my rear pads and had to replace my front pads at 50k because despite having plenty of life left they'd begun to rust to the caliper due to age (Car was at that point over 6 years old on its original pads!). My current F10 is on 8k miles and reckons I've only got 19k left front and back! I'd be somewhat irritated if that turns out to be true...
Current: 2021 M340i xDrive, 2001 530i Sport
Previous: 2015 530d M Sport, 2010 530d SE, 2008 335i M Sport |
09-27-2016, 03:37 AM | #29 |
Rep 54
Hi Fox, thanks for your detailed response.
My experience with iDrive has been different, or rather, like yours, it seems to reach a certain number and then stop there for ages, before it continues again. So I don't think 2200 is a "magic number". For example, my front brake pads stopped at 10000 and didn't budge for months and months, and then suddenly dropped to 1600. Now they're stopped at 1600 again. Different numbers again with rears. All in all, in my experience at least, these numbers are nearly useless. I mentioned in another thread, that when I picked up my car from the dealer, when I bought it (approved used), it was showing 130000 (yes, one hundred and thirty thousand) for the front pads? And that number wasn't changing either, for months as I drove the car, until I mentioned it to another dealer, when the car was in for its regular service, and they returned the car to me with that number down to 19000 (how or why they picked 19000 is beyond me). They didn't explain it to me either when I asked. |
09-27-2016, 06:45 AM | #30 |
Rep 582
Interesting, I assumed 2200 was the 'magic number' as both our cars stopped there and only there - it seemed an odd number until I realised it was 3500km.
I suppose the reality is that everyone wears brakes differently and the physical pads themselves are not high tech or fitted with expensive reporting sensors, so it's a 'best effort' guess using a bunch of estimated parameters. 130000 seems mad - when mine was reset after new pads it displayed approximately 45-50k to go. Which makes 18k left on my 8k mile car all the more odd really!
