2010 2011 BMW 5 Series Forum F10 No start, no crank after replace plugs and coils ****FIXED**** |
01-31-2024, 08:41 PM | #23 |
Rep 102
Let us know if the starter is the culprit, same thing happened to my moms x3, I’m sure it is just the starter though, did it ever have a not necessarily slow but a weak crank when started? It is an older car at the end of the day.
ChiltiCoatl891775.00 |
02-01-2024, 11:03 AM | #24 | |
Rep 21
You know, it's hard to say, we only had the car 3 weeks when this happened. Possible, but then we never witnessed it when it was new. Buy yea, 107k miles. It's high time to replace anyway. I'm hoping this is it, but not throwing cash away if not. Preventative maint. Same with the battery I just replaced. |
02-01-2024, 11:18 AM | #25 |
Rep 3,035
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
I anecdotally believe that starters on F10 cars are not the strongest. Whether the start/stop (which I don't have) wear on them, or something else, I sense they give out around 100-125,000 mile range. I haven't had to replace one on any of the E90s I've owned.
02-01-2024, 03:46 PM | #26 | |
Rep 5,379
02-01-2024, 03:52 PM | #27 | |
Rep 3,035
02-02-2024, 12:40 AM | #28 |
Rep 436
Drives: 2016 F10 BMW 535i M Sport
Thanks Colonel! and General! You and a few others are always so helpful!
StradaRedlands4965.50 |
02-02-2024, 08:11 PM | #29 |
Rep 127
Very 1st thing I did to my car was disable A/S/S in 'comfort mode'. Now I have to figure out if I can do the same for 'Eco PRO MODE' too.
StradaRedlands4965.50 ChiltiCoatl891775.00 |
02-02-2024, 10:54 PM | #30 |
Rep 436
I just keep it in comfort when i am commuting or traveling more than 200 miles, unless there is an encounter, Sport+ Engaged lol, That way i never deal with A/S/S.
02-03-2024, 08:58 AM | #31 |
Rep 127
02-03-2024, 12:03 PM | #32 |
Rep 5,379
Conserve186.00 ChiltiCoatl891775.00 |
02-11-2024, 01:01 PM | #33 |
Rep 21
This car. Already about to roll it off a hill. Can't find the supposed neutral emergency lock that is supposed to be somewhere, either under the cup holder, which it's not, or somewhere else. I've seen videos where it's under the shifter surround. But I don't think the surround on this sifter pops right up like some of those I've seen.
Anybody know where the heck I'm supposed to find it? Seems like they just willy-nilly put it anywhere from year to year. Grrrr |
02-11-2024, 01:24 PM | #34 |
Rep 1,873
The F10 has no such thing in the interior. You have to get under the car and screw in a bolt on the transmission. However you're googling, it's not for F10 specific info. This usually comes into play with a dead electrical system:
https://youtu.be/GIAxM4RMmfc?si=-qmtAUyFbEbSnnFA&t=548 Now - I have seen more indications of alternatives when your battery isn't dead. For those cars with a strap under the cupholder, that would be as easy as anything else (battery dead or not). I have heard of another technique when you have power, which I've never tried. https://www.youtube.com/watch?v=2Jwd-g3L5pI I would expect both are covered in the manual too. |
dbatech9925.50 StradaRedlands4965.50 |
02-11-2024, 01:42 PM | #35 |
Rep 234
Drives: 2015 BMW 535i M Sport
As Surly73 said above there is no manual release from within the interior.
There are (2) methods - electronically & mechanically. See attached pdf for the TIS procedures (from my "emergency" notes I put together. Pages 3 & 4) |
02-11-2024, 01:50 PM | #36 |
Rep 234
Well....You'll have to get the transmission disengaged out of park before you can push it down the hill....
Your frustrations are understandable. IMHO, that manual allen bolt release on the side UNDERNEATH the car is absolutely ridiculous. Especially in situations where a guy finds himself broken down in an area where he's blocking traffic and just needs to push the car off to the side of the road. Don't forget to breathe and good luck! |
02-12-2024, 06:39 AM | #37 | |
Rep 21
I need to tow strap the car up my crazy steep driveway to get it into the garage, so I can put this new starter in. |
02-12-2024, 08:54 AM | #38 | |
Rep 234
You got this Dad. You'll get that beautiful Bimmer up and running and your daughter wil be sooooooo happy. Good Luck and please keep this post updated. I've been interested to see how this one turns out (hopefully not the downhill scenerio...lol) |
dbatech9925.50 ChiltiCoatl891775.00 |
02-13-2024, 01:59 PM | #39 |
Rep 21
Well, unfortunately I've tried countless times with the above directions and either you can't do this with this car or I'm doing it wrong. I don't see how I could be doing it wrong because the directions are pretty simple. Looks like the only option is for me to get under the car. Which is a bit bizarre cranking up the car on a jack and then putting it in neutral while I'm under the car lol. Just seems really bizarre and I can't fault BMW more for such a crazy convoluted difficult way to put a car in neutral.
02-13-2024, 03:31 PM | #40 |
Rep 234
From my convoluted understanding of BMW, it sounds like the starter needs to at least try to turn over in order for the electronic disengage method to work.
Here's a link to a good previous discussion on the subject. Notably, post #7-9 https://f10.5post.com/forums/showthread.php?t=1683926 |
02-13-2024, 04:18 PM | #41 | |
Rep 21
Now, when I get time, I can replace the starter in the calm serenity of my garage... THis will prevent me getting in trouble with the HOA due to audible disturbances that might (will) occur from working on this thing. Thanks everyone for the help so far. |
ctcarbonari295.00 StradaRedlands4965.50 |
02-25-2024, 02:01 PM | #42 |
Rep 21
UPdate. Got the intake almost off, but getting foiled by the electrical connector underneath. Had a good youtube tutorial that was doing a great job of detailing each connector... until he got to this one and said. "It's a standard connector, I used a pick tool". Doh... there isn't much room and I can't seem to get it to release. Any suggestions?
**** DELETE RANT***** OK. So I got the connector off. Apparently you are supposed to squeeze it, and it should pop off. However I depressed it all the way and it still would not release. So I carefully inserted a screwdriver head and leveraged the end up on the opposite end and it released. Thank God. Last edited by dbatech99; 02-25-2024 at 03:01 PM.. |
02-25-2024, 08:02 PM | #43 |
Rep 21
New Starter in. Success! Car start. Thanks to everyone's help.
02-25-2024, 08:05 PM | #44 | |
Rep 234
+1 to having a hook & pick set. That has helped me out a lot - even when I'm using them to pry loose and break free once released and still seem to be stuck. OP: I've been enjoying reading the updates on this thread. Nice work! |
