2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wash, Wax, Detailing and Cosmetic protection/repairs Carbon Fiber rear diffuser fitment
      07-22-2017, 08:10 PM   #1
MpJaj
MpJaj's Avatar
Drives: F10 550i M
I have a Vorsteiner Style CF rear diffuser that im trying to adjust to fit better. Basically if i push it up with my hand it fits perfectly but when i let go its natural position leaves a small gap. show in the picture (link below)
https://photos.app.goo.gl/YwTA7iYuwNyP2RUG3
Anybody know what the best way to go about fixing this would be? I tried double sided tape but it didn't work very well.
Thanks!
      07-23-2017, 07:34 PM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
is this aftermarket? if they are than the tabs you could probably add screws from the inside to hold them in place. what you would have to do is remove the rear bumper to do this. when you push up on the diffuser look on the other side where the tab pulls through and when you have it pushed in you'll take a drill and drill a hold through that tab. than insert a screw and it should hold the diffuser in place. it's what i had to do on mine
      11-08-2017, 05:54 PM   #3
BuiltnBoostedZ
Drives: 2012 535ix
I had the same problem with my carbon rear diffuser. I removed...plasti dipped the gap and it looks good now. If you aren't happy with that, you can use weather stripping. If done right, the plasti dip looks good.
      12-03-2017, 10:58 AM   #4
Johngm45
Drives: 535xi m sport
I am having the same problem. I tried two sided industrial tape to see if it holds up.
The fitment issue was on driver side only just as your picture shows.
