2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes BMW M5 to F10 DIY Brembo Brake conversion
      03-14-2022, 01:28 PM   #67
PepMo
Drives: 2014 535i
Originally Posted by kelson teh View Post
hi all... amazing work guys, i just got my 535i about 9 month,
done installing brembo 19z on my car, but i feel the brake is way more softer than the original, if the master cylinder is help, any chance i can have the part number so i could find it and replace. or is the 19z make the brake feel soft???appreciate it...
How did you fit those on your F10? No adapters needed?
      04-14-2022, 10:43 AM   #68
nungcs52
Drives: F10
Update 14/04/2022
After use ISTA+ brake bleeding result is same issue. I found brake bleeding don't have bubble and foam.
ISTA + DCS unit control test
Brake pressure values
Reae axle brake circuit pressure : state = -21.80 bar
Front axle brake circuit pressure : srate = -21.80 bar
Before case.
today, I change brake set to m5 f10 front and back.
issue is brake fade such as press brake but brake has no power to press on the brake disc.
brake bleeding no air bubbles.
help me please.
      04-14-2022, 03:47 PM   #69
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
Originally Posted by nungcs52 View Post
Update 14/04/2022
Before case.
help me please.
You're bleeding both sides of the caliper, right?
2015 BMW 535xi
ISTA VM Setup/Tutorial
      04-16-2022, 05:21 AM   #70
Blue Angel
Blue Angel's Avatar
I will put my response to your other thread here. You shouldn't have two conversations about the same thing. You should delete one and keep the other.
Brake fade is what happens when brakes overheat from heavy use. It sounds like you have a completely different issue.
Assuming you have done the bleeding process properly, you may have a mechanical issue like a defective master cylinder. If the seals in the cylinder are leaking you will not be able to build pressure in the system and the pedal will drop to the floor when pressed.
      04-26-2022, 12:39 PM   #71
mikekilpatrick
mikekilpatrick's Avatar
I will point out that I installed my Brembo on my 550xi Msport. When I did the research, i found that the M5 and 550 had a similar sized Master cyclinder, and my Brake rotors were larger than a 4 or 6 cyl F10.
If you are not running a V8 Msport, you might want to ensure your master cyl is the same capacity. I have not researched this.
      04-28-2022, 05:33 AM   #72
Blue Angel
Blue Angel's Avatar
According to realoem, every single F10 model from the 518 to the M550dX uses the same master cylinder 34336796729:
https://www.realoem.com/bmw/enUS/par...38;series=F10N
The F10 M5 uses a bespoke master cylinder 34336799903 that no other F10 model uses:
https://www.realoem.com/bmw/enUS/par...#38;series=F10
I don't know what the difference is between them, but they are different. The F10 M5 uses six piston calipers with 7% less piston area than the 60mm single piston calipers on regular F10s, so it's possible the M5 master cylinder has less displacement.
EDIT: if you're interested in the specs of all the different OEM upgrade options for the M5, I put together a chart showing the differences here:
https://www.bimmerpost.com/forums/sh...php?p=28731092
      05-02-2022, 10:26 PM   #73
Unspec
Unspec's Avatar
1301
https://www.realoem.com/bmw/enUS/par...29&series=F10N
https://www.realoem.com/bmw/enUS/par...903&series=F10
There's quite the casting difference in the M5 vs non-M5 masters.
M5: https://www.schmiedmann.com/en/34336...linder#gallery
Non-M5: https://www.schmiedmann.com/en/34336...linder#gallery
2015 BMW 535xi
      05-04-2022, 05:55 AM   #74
Blue Angel
Blue Angel's Avatar
Nice find! Looks like the F10 version is 22.2mm and the M5 is 26.9mm. Quite a difference (32% more area)! Perhaps to decrease the amount of braking torque per a given pedal force due to mechanical advantage and aggressive brake pads?
The casting is different where the lines attach, I wonder what else changes throughout the M5 system? I wonder if the booster is the same…
      05-04-2022, 07:01 AM   #75
ptrkp
Drives: F10 or F11
Booster is bigger. you need to replace one of in the incoming brake lines.
      05-04-2022, 08:15 AM   #76
Blue Angel
Blue Angel's Avatar
So it's a hydraulically stiffer system (less mechanical advantage) due to the larger master cylinder, and they compensate with a larger brake booster. Interesting - thanks for the info!
      05-05-2022, 09:08 AM   #77
mikekilpatrick
I am still curious how some people experience soft brake pedal after installation and bleeding while when I did the upgrade, had no issues. Have had this on the car for about two years or more with no issues.
Has to be something that is different. I bleed the system with one person pressure pump and then had it bled by dealer last time I had it in for service. Same peddle pressure both times. While others have performed repeated bleeding and still report soft brake Pedal problems.
      05-05-2022, 10:09 AM   #78
Unspec
Unspec's Avatar
1301
Personally I think it's people not fully bleeding all the air out. It took me 2 bleed to get a firm peddle.
2015 BMW 535xi
      05-05-2022, 02:13 PM   #79
Hoa
I agree with Unspec. I've done many BBK upgrade for my cars without any soft pedals. I always flush in the following order: RR, RL, FR and FL. I switch between ATE amber and blue every time I flush the fluid to make sure I'm getting completely new fluid through the lines. I still do brake flush with one pumping the pedal while the other open the line. Old school but works for me lol
