2010 2011 BMW 5 Series Forum F10 Yet Another 20" Wheel Fitment Thread |
07-26-2020, 02:54 PM | #1 |
Petrolhead
440
Rep 808
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
I've already gone through all of the previous threads and made some sense out of the at times contradictory info, but I'm still not sure what the best tire option is for a 550i xDrive.
Current 19 Setup:
New 20" Wheel Setup:
550i xDrive 20" Recommended Setup: While this is recommended size by BMW and lots of members here (or 285 for rear), are the tires wide enough for new setup?
M5 20" Recommended Setup: While tire width same as new setup, I’ve read these tire sizes will rub.
Here is what I'm looking for in order of importance:
Really appreciate the input. Have been reading and researching all weekend.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) Last edited by spielnicht; 07-26-2020 at 03:13 PM.. |
07-26-2020, 09:05 PM | #2 |
Rep 2,591
If you're lowering, your best bet is 245/35/20 and 285/30/20. I have rear 295/30/20 on the M5 343M wheels and it's already pretty tight on stock suspension, will probably rub if you lower.
Since you're xDrive, you can't have the total diameter of the two wheels differ by more than 1%
2015 BMW 535xi
07-27-2020, 03:55 PM | #3 | |
Petrolhead
440
Rep 808
Thanks for the info. Pulled the trigger and went with the 245/285 setup. Can't wait for the wheels and tires to come in.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
04-23-2022, 09:54 AM | #4 |
Rep 8
Yo, what size would you go with then? Im xdrive and need to buy tires with this set up.
The dude was running 20x10et25 squared. But i need tire size. wondering if I should do a squared set up or a staggard one. if staggard what size? |
05-09-2022, 08:02 PM | #5 |
Rep 109
Will a 20x9 ET: 30 work on a 245/35/20 squared setup work on a 2016 F10?
Current - 2025 G05 X5 xDrive40i, Black Sapphire Metallic
Sold - 2021 G01 X3 M40i, Black Sapphire Metallic Sold - 2016 F10 535i xDrive, JET BLACK |
