2010 2011 BMW 5 Series Forum F10 Possibility of retrofitting a N55/N20 engine oil cooler WITHOUT changing coolant line |
10-17-2022, 05:10 PM | #1 |
Rep 2,591
First, Stuck's excellent guide on the actual OEM retrofit:
https://f10.5post.com/forums/showthread.php?t=1399982 It's a pretty complicated and involved retrofit that requires removal of the downpipe and such. I think we all know how much of a pain in the ass doing that downpipe removal is, so I never really gave it much thought. After all, it's not like I track this car. However...I recently stumbled upon THIS gem: Kit: https://www.aliexpress.us/item/22558...b-36456f41c3a8 Plate only: https://www.aliexpress.us/item/32568...3-d0d5eb7365e4 For 32 BUCKS SHIPPED! It states for N20's, but the OFH is actually the same part across all N20's and N55's, so any plate for the N20 will fit the N55. It has 3 ports: two for oil and, most importantly, one for coolant, all AN10. The Kit includes a nice 90 to barb adapter, and that's exactly why this kit is so exciting to me. It allows you to put the old coolant line for the coolant-to-oil heat exchange on and just act a straight return. Does it waste bit of cooling capacity? Sure. But it's not like the N55 really suffers from coolant cooling issues, and this would be minuscule. Alternatively you could probably plug the old line and achieve the same thing, but I have concerns with potential leaks given the pressure the system is under. This allows you to just simply flow the coolant back into the loop. Some concerns, obviously:
Interested in hearing people's thoughts on this and if they foresee any issues that I haven't seen.
2015 BMW 535xi
