2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Shaking under harder acceleration at 80+ MPH
      09-03-2022, 02:29 PM   #1
Jimmy_Brooks24
Drives: 2012 f10 535i
Getting a weird shaking in the floor boards bad enough to feel it in the seats. It only happens under harder acceleration at 80+ MPH. When I rev the car at a stand still there is no shaking, and when accelerating hard from lower speeds there is no shaking. The steering I wheel doesn't shake so it's not likely to be unbalanced wheels. I checked under the car and all the suspension bushings look good. It almost feels like it's coming from the transmission or drive shaft. Bad transmission mounts? Could it be differential related? It's a 2012 535i M-Sport RWD with 77k on it, completely stock. Anyone have any idea?
      09-08-2022, 01:48 AM   #2
550bye
550bye's Avatar
Drives: 2011 550i
2011 BMW 550i  [5.67]
Check your Guibos or 'flex disc'. Depending on the model you may have 2. My rear guibo wasn't as in bad shape but the front was in terrible shape. Check the link for photos. I'd start there.
https://www.bimmerpost.com/forums/sh...php?p=28738962
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
