2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Drivetrain malfunction error - intermittent
      09-15-2022, 07:13 AM   #1
Haval
Drives: BMW 520d
Hello guys,
Apologies if this has posted else where but All of sudden I've started getting this drivetrain error and disappears. I've checked the codes that are available to me on BimmerLink but could someone please help me to decipher what these codes mean. I don't want to take to a mechanic just yet but need to make sure I know what's exactly wrong.
12 Motor electronics
4 errors
255B00: Exhaust gas recirculation actuator high pressure, position control: positive control deviation
272F00: Exhaust gas recirculation actuator high pressure, position control: mechanically defective near open position
272E00: Exhaust gas recirculation actuator high pressure, position control: mechanically defective near closed position
282B00: Exhaust gas recirculation rate control, system deviation: exhaust gas recirculation rate too low / positive system deviation
63 Headunit/radio
1 error
B7F8C3: CID does not respond (hardware error: failure of CID communication
Link to pdf reports
Memory codes: https://we.tl/t-EeQTAWlUZO
Current codes: https://we.tl/t-V3Xg440Yld
      09-17-2022, 01:07 AM   #2
Sequence001
Sequence001's Avatar
Drives: 2019 X5 & 2024 i5
2019 BMW X5  [10.00]
I was getting this error constantly. After a ton of trial and error, we came to the conclusion that It was my differential pressure switch. It worked and was fine for a few months then the error came back randomly. No one has been able to figure it out at the shop since, so I'm just dealing with it. Its currently not affecting performance so I'm not going to dump any more money into finding the cause. Good luck.
