2010 2011 BMW 5 Series Forum F10 2011 535i Tilt/Sunroof Malfunction |
12-08-2013, 01:49 AM | #1 |
Rep 39
I have a tilt/sunroof malfunction. I opened my sunroof today for the first time in like ever (not a full open just a tilt) and now it won't close. I did the hold down the tilt button for(15,30,60sec) but no reset initiation. I heard the clicks after like 15 seconds but it does nothing. I took a flashlight and looked for anything blocking the tracks or whatnot but nothing. I guess its time for the dealer
12-08-2013, 08:01 PM | #2 |
Rep 653
You did this with the engine running, right?
Push the sunroof button up and hold it the whole time until the reset process is completed and the sunroof shade closes. |
StradaRedlands4933.00 |
05-14-2016, 12:52 AM | #4 |
Rep 697
Drives: 2013 535xi
This reset process works as advertised. Thanks v12. We recently had some hot weather, and I discovered two things that were not working correctly: the air conditioning and the sun roof. It took a refrigerant recharge to fix the former, but I was able to perform the reset procedure for the latter.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) Last edited by cdmulders; 05-14-2016 at 02:15 AM.. |
01-31-2017, 10:43 AM | #5 |
Dream crusher
984
Rep 2,421
This just happened to me and the up and hold isnt working after removing and reinstalling the battery. The sunroof doesn't make aso me or any movement.
Any other suggestions?
IG: @bmwdoubles |
05-28-2017, 06:14 PM | #6 |
Dream crusher
984
Rep 2,421
Fixed mine, accidentally. The push-button reset sequence didn't work for me because the button wasn't responding. Reset the code and still no movement. Just had my clutch done which required the battery to be pulled. After plugging the battery back in everything started working again! I know I mentioned above that I tried that, but the battery was removed for a long time so maybe that's the difference.
Sunroof life!
IG: @bmwdoubles |
09-26-2023, 12:40 AM | #7 |
Rep 2
12-18-2023, 03:26 PM | #8 |
Rep 21
For the reset to work, the car must be running correct? If I start with the shade and glass in the closed position, which way should the button be pushed? Toward the front glass or the rear glass? Thanks.
EDIT: Read another thread and figured it out!!!!
2011 BMW 535i, 6spd, Milano Beige Metallic, Venetian Beige Leather, Convenience Package, Premium Package 1, Premium Package 2, and Sport Package. 119,500+ miles.
12-18-2023, 04:19 PM | #9 | |
Rep 7,475
And DO check your owners manual because some models require the engine to be running and some don’t.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-18-2023 at 04:30 PM.. |
12-19-2023, 06:15 AM | #10 |
Rep 21
Just to add, the button to operate the glass and cover has to be pushed straight up....not towards the front or rear glass....just straight up and hold it until the roof goes through it's complete cycle. Thanks for the page out of the manual QSilver
