2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 550i misfire under hard acceleration.
      05-17-2017, 11:10 PM   #1
aythatblackguy
Drives: 2006 325i,1995 740il,2002 x5
So my 2011 550i has has started to misfire under acceleration. If i drive like a grandma everything is fine but when i down shift to pass someone i get a drivetrain malfunction. Now the bmw dealer i got the car from replaced all 8 injectors and all plugs and coils before i bought it 400 miles ago so what gives.
      05-18-2017, 08:06 AM   #2
Bbmw535
Drives: 535i
Sounds like plugs maybe coils. Not sure why they replaced everything. I had a missfire issues twice and one time happene to be plugs, second time one of the coils was bad.
      05-18-2017, 08:33 AM   #3
aythatblackguy
Oh I forgot to mention it's only cylinder 1-4 that are misfireing
      05-18-2017, 08:56 AM   #4
Bbmw535
Drives: 535i
Sounds like bad plugs or coils. I would take it back in and have it inspected before something else goes wrong
      05-18-2017, 09:57 AM   #5
Ironman273
Ironman273's Avatar
Drives: 2011 BMW 550i 6MT
That happened to me. I had to replace the exhaust VANOS solenoid for that bank and it fixed it.
      05-18-2017, 10:34 AM   #6
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
I had same issue only misfire on CY 8 like you said if I drive slow its fine as soon as I step on it over 2 RPM its throws out drive train malfunction.
Frist two times I took it to dealer they told me they couldn't replicate issue.
just other day I was coming back from store I step on it and there it goes Drive Train Malfunction. I was furious took it in show the manager as car was shaking like Hell
I told them to keep car for month if they have to @ that point I dint give a S#it.
Next day they called me SA told me they replaced coil 8 and spark plug its been good.
I hope it doesn't come back.
Good luck
      05-18-2017, 11:19 AM   #7
A bad coil will take out a good coil and a bad coil will take out a good plug. They "should" normally be replaced together if one has failed.
      05-18-2017, 08:46 PM   #8
aythatblackguy
Im going to rule out plugs and coils because they are all new.
      05-18-2017, 10:24 PM   #9
Ironman273
Ironman273's Avatar
https://bmwtechnician.com/2016/05/12...os-solenoid-2/
      05-18-2017, 10:29 PM   #10
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
It could be anything from MAF, plugs, coils, or injectors. You need to get the codes read with BMW capable software, otherwise it's a crap shoot on the diagnosis.
      05-19-2017, 10:34 AM   #11
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
be careful even if you install new plugs and coils you still can have defected coil or plug.
      05-20-2017, 01:00 PM   #12
mpbmw94
mpbmw94's Avatar
41
Drives: 2013 550
HPFP, should be replaced, I had the same issue after replacing coils, plugs and injectors. So far so good, hope this helps.
      05-21-2017, 12:44 AM   #13
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Codes are the first step to healing. You can't replace random parts and hope all goes well.
IG: @bmwdoubles
