2010 2011 BMW 5 Series Forum F10 535i 2013, front bearing hub. |
02-18-2017, 06:40 AM | #1 |
Rep 11
hi;
WHEN I REPLACE MY ROTORS AND PAD OF MY 535I A FEW WEEKS AGO, WITH THE CAR LIFTED, I COULD HEAR A GRINDING NOISE WHEN I TURN OVER THE FRONT WHEELS BY HAND, BOTH SIDE SAME NOISE. IT'S NOT PAD OR ROTOR NOISE. THE NOISE IS ONLY AUDIBLE WHEN TURNING CLOCK WISE, NOT WHEN MOVING WHEEL IN THE OPPOSITE DIRECTION (REVERSE) DRIVING IS NOT AUDIBLE!!! IF THE HUB BEARING WERE BAD, THEY WOULD GRIND IN BOTH DIRECTION, IS THAT RIGHT? MY LOCAL DEALER SAYS IS NORMAL!!! AS USUAL!! THANKS, DIEGO. |
02-18-2017, 07:37 AM | #2 |
Rep 14,521
grab the wheel at the 9 and 3 or 10 and 4 or whatever the clock position is lol and see if there's movement as you pull forward and back to see if there's play. couple of things...how many miles are you clocked on the odometer? are you lowered? spacers? those are a few things for wheel bearings to take a $hit
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
