2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum I wish I got the integral active steering option!
      03-13-2012, 03:22 PM   #1
aosman
aosman's Avatar
Drives: 2023 760i G70 & 2020 M8C F91
I came from a E60 545i where the AS was standard (on the 2004 model) and I really got used to the effortless steering especially in garages and parking...
But this is not why I wish I got the AS in my F10. The real reason is that I find the F10 hard to steer at speeds over 45MPH even on a mild bending roads. I live in Houston where most roads are straight but on the curvy ramps and some parkways I feel that the steering is too heavy and take considerable effort to keep the car turning with the road...
Steering the rear wheels as in AS option would've helped a lot I think.
I also wish BMW designed the steering with a lighter feel.
Just venting out...
      03-13-2012, 04:01 PM   #2
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
I thought AS feels heavier than the standard. Do you have the xDrive model?
      03-13-2012, 04:38 PM   #3
aosman
aosman's Avatar
I have the rear-wheel drive (no x-drive) 550i.
The back wheels in AS are supposed to turn up to 2.5 degrees to help out... why would it make it harder?
      03-13-2012, 05:10 PM   #4
stealth.pilot
Knight Commander
stealth.pilot's Avatar
Drives: 2014 911 Turbo S
Active steering is fantastic. Not only does it improve ease of parking, but it dramatically improves handling in high speed corners and lane changes.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      03-13-2012, 05:52 PM   #5
Needsdecaf
Needsdecaf's Avatar
6599
Drives: 2024 G80 Comp xDrive
Just venting out...
If you came from an E60 to an F10 and you think the steering should be lighter, then something is wrong with your car. The F10's steering is quite a bit lighter than the E60 steering (note, I have not driven an AS E60).
But honestly, you may want to drive another car and see if it's the same. Because you would be the first to have this issue.
      03-13-2012, 05:59 PM   #6
bimmerjph
bimmerjph's Avatar
Drives: 2005 Z4 3.0
Yeah I was going to say that too. If you think that the F10 steering is too heavy, please refrain from telling BMW. I don't want its successor to have a corolla steering weight.
      03-13-2012, 10:10 PM   #7
JNoSol
JNoSol's Avatar
+1, My F10's steering feels too light compared to my E70 Sport. Damn electric assist.
      03-14-2012, 02:52 AM   #8
LiveLarger
Norway
Drives: F11 520d M-sport
I have a problem seing how the active steering would improve high speed cornering?
      03-14-2012, 04:50 AM   #9
delvek
delvek's Avatar
Germany
33
Drives: 2014 550i Msport
Agree with you 110%
I had an e60 535i prior to my f10 550i. My f10 550i far surpasses the handling capabilities of my e60 535i. My own personal observation.
For my driving purposes, I would never consider this car without the IAS if your going to be taking slopping highways very fast as the stability that is created by IAS is incredible.
2014 550i M-sport
      03-14-2012, 05:51 AM   #10
AC_S5
AC_S5's Avatar
9
Drives: 2011 F10 523i
I think the active steering, like all driver aids help stability by electronically eliminating the tiny input/movement that the driver mistakenly made on the steering wheel during high speed (ie. unstable hands).
2011 F10 - Sophisto Grey / Cinnamon Brown
You can find me in E60.net too!
Gone (but not forgotten)
2005 E60 523i, 1999 E39 523i, 1998 E46 323i
      03-14-2012, 06:26 AM   #11
LiveLarger
Norway
To me that sounds like making the steering worse, not better. It should be direct!
      03-14-2012, 06:42 AM   #12
AP
AP's Avatar
2782
Drives: G30 M550
I never thought I see the words 'heavy' and 'steering' in the same sentence when talking about a F10!
      03-14-2012, 07:41 AM   #13
delvek
delvek's Avatar
Germany
33
After my intimate experience with my F10 I would relate "heavy" more closely to my steering then "light".
2014 550i M-sport
      03-14-2012, 10:45 AM   #14
stealth.pilot
Knight Commander
At high speeds, both wheels move in the same direction which reduces body roll and reduces centripetal force on the tires.
      03-14-2012, 11:41 AM   #15
LiveLarger
Norway
In cornering you are limited by grip and four wheel steering isn't going to change that. Same reason it's not used in racing. Ads complexity and weight, but no real benefits.
I do see your point about it feeling nice and stable. It's probably great if you are pulling a trailer. Same for lane changes. But for pure handling when having fun in the car, I still can't see how it would be any good.
      03-14-2012, 12:54 PM   #16
Bimmernerd
Bimmernerd's Avatar
Sweden
Drives: 530dM xDrive F11 2012
I'm glad I have a F11 with xDrive and thus hydraulic steering instead of the criticized electric steering...I think the steering in my car is perfect, light at low speeds but with a heavy but not too heavy feeling at highway speeds
      03-14-2012, 01:54 PM   #17
hinckley
hinckley's Avatar
3493
Drives: '24 M4C Conv
I had AS in both my 04 545 and my 08 550. It was and is an optional item (never standard).
AS is often misunderstood. It does not in any way change the "effort" as it relates to the steering's relative heaviness or lightness. Instead, AS changes the steering ratio at different speeds. At slower speeds it takes fewer rotations to go "lock-to-lock" than it does at higher speeds.
For those of us who live in cities with tight corners or a lot of parallel parking, AS is absolutely fantastic. OTOH, some enthusiasts dislike the fact that the steering ratio can change pretty dramatically on hard acceleration through a sharp curve, like a freeway onramp.
But like most technologies, it's pretty easy to get acclaimated to AS. Back in 04, I almost hit a curb by turning the wheel too far on my first day out. After that, I've never had a problem.
To me, it's one of those things that you'll never miss if you've never had it. But once you get it, you'll be hooked (you'll noticed that the only people that dislike AS are ones that don't have it).
      03-14-2012, 04:21 PM   #18
aosman
aosman's Avatar
Sounds like you payed for something that was supposed to be included in the 04 545! it was part of the sports package on the 04 545i only.
      03-14-2012, 06:40 PM   #19
Needsdecaf
Needsdecaf's Avatar
6599
It's not used in racing because it's banned, not because it doesn't work.
      03-14-2012, 07:20 PM   #20
hinckley
hinckley's Avatar
3493
ah . . . well . . . AS was part of the Sport package, a $3,300 option on the 04 545. I think that makes it an option, right?
      03-14-2012, 09:10 PM   #21
AC_S5
AC_S5's Avatar
9
I don't think so. Although I don't have that option, but imagine if you have the same steering ratio at any speed, a quarter turn at low speed doesn't have as much effect as say when you are travelling at 100+km.
So by change the steering ratio during high speed, it helps with stability as the steering is so light on the F10. You may not notice it as much on the E60, but on the F10 I can definitely feel the steering is too light, in fact the steering has been lighter and lighter on newer models. The best steering I think was the E39, nice and firm but not too much effort like on the E46 and E90.
      03-14-2012, 09:16 PM   #22
AC_S5
AC_S5's Avatar
9
The idea of active steering just like all other safety features that we have on our cars like traction control, ABS all comes from racing technology. But it was banned because FIA thinks it takes the driver out of the equation and speed was getting faster and faster with all the drivers aids.
