2010 2011 BMW 5 Series Forum F10 EPS error & xenon modules |
02-13-2023, 07:25 AM | #1 |
Rep 35
Hi,
- Today I've tried to code in F11 new steering column after replacement. Power steering was working normally, however I didn't have any cafd file in EPS module, so I searched for swe, selected the bottom one and coded then. Coding was unsuccessful, I get an error and power steering stopped working. I've never have any errors with coding. What can make the errors, old psdzdata or something different? - I have one more question about headlights modules. I didn't see modules connected with headlights, only FRM, but I have to code module of left headlight as it doesn't work after replacement. Which ones are xenon headlights modules? Picture attached |
02-13-2023, 09:57 AM | #2 |
Rep 40,793
Drives: 2018 Alpina B6 650ix GC
PM me car VIN and Donor EPS VIN.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
02-15-2023, 10:57 AM | #4 |
Rep 35
shawnsheridan I've tried to flash EPS as per your instruction. Unfortunately I had some errors.
Pic 1 Firstly I've flashed ZGW without any problems and ZGW disappeared from the TAL list. After that I've tried to do the same with EPS [30]. Pic 2. Before ZGW flash Pic 3. After ZGW flash As I understand to flash EPS I had to check: tl_13, tl_21, tl_51 theirs PreRequisites. 1)TalLine_13 -> tl_18 & tl_6 2)Talline_21 -> tl_18 & tl_6 3)Talline_51 -> none tl_18 & tl_6 are parts of DSC2 and they don't have any PreRequisites. Summarizing I've checked all available boxes of DSC2 and EPS to flash and I've get an error as attached. |
02-15-2023, 11:09 AM | #5 | |
Rep 40,793
Do exactly as follows: 1) Read FA 2) Select Read VIN our of FA & "Read VIN" 3) Then do all of the ECU Selects - blflash... 4) Do the Check Software 5) Then select the "Read VIN out of FA" which greys out the "Enter VIN" 6) Then do the Start...
barni3204.00 |
02-16-2023, 06:09 AM | #6 | |
Rep 35
What about xenons? Do they have any separate modules to code/flash? One headlight doesn't work correctly. DRL works , low and high beams don't. I've attached the list of my modules. |
02-16-2023, 06:15 AM | #7 | |
Rep 40,793
No, you have only FRM Module for Xenon lights.
02-16-2023, 06:31 AM | #8 |
Rep 35
Ok, I've flashed the FRM, selected new cafd and coded, no errors but it didn't help.
I suspect also a broken xenon converter itself. Awaiting for new part already. Do xenons require any coding or they should work p&p after module replacement if the car was originally xenon fitted? |
02-16-2023, 06:32 AM | #9 | |
Rep 40,793
02-20-2023, 11:03 AM | #12 |
Rep 40,793
