2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BMW F10 autotrunk HKFM module not found in E-Sys.
      03-05-2023, 03:10 AM   #1
asprs
Drives: BMW F10
Hello Community!
Have an issue after retrofitting bmw f10 lci 2014 with autotrunk 316 option.
Installed the full set of autotrunk hardware, all wire connected according to Tis.
Added 316 option in FA in E-sys.
But the module is not seen in Ecu list in E-sys while I want to code.
K-Can h and low connected, voltage 6-high, 0.5-low on the hkfm module.
12v also on hkfm pins.
what can be the issue?
Thank you.
      03-05-2023, 11:00 AM   #2
TheNine90
Drives: bmw
You try writing the FA to vcm and coding any module. Are you using the READ ECU button or READ VCM?
      03-05-2023, 01:33 PM   #3
asprs
Drives: BMW F10
Sorted.
Wrong wire to k-can.
All works fine now.
Thank you.
      03-21-2023, 09:50 AM   #4
dormidont
Drives: BMW F11
Is coding possible in this case
Originally Posted by asprs View Post
Hello Community!
Thank you.
Hi. I have 2012 F11 with comfort access. But on the trunk there is only one button with a lock sign on it. If you press a trunk open button on the remote, or use your foot to open it, or click the open button inside the car, it only clicks and unlocks, but you have to move/open manually.
In the coding I managed to find how to choose should it open the tailgate glass or the trunk, but then again, it only unlocks. For me it does not make any sense - why would you unlock it by foot, if you still need to open it by hand..? Do you know by any chance is there some advanced way to code it?
PS Also having a button on the trunk just to lock the car does not make any sense to me.
