2010 2011 BMW 5 Series Forum F10 N55 Valve lash inspection? |
03-09-2020, 10:37 AM | #1 |
Rep 175
Does the N55 engine require periodic valve adjustments? Asking about a F10 535ix with N55 engine. If so, how often and how much do independent ships charge? Any DIY's?
03-09-2020, 11:42 AM | #2 |
Rep 1,299
03-09-2020, 03:50 PM | #3 |
Rep 668
I thought valve lash adjustment was only for flat tappet lifters (such as those in the S50 engine from the 90s). Nxx engines I believe all have hydraulic lifters so no adjustment is necessary
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
03-11-2020, 08:07 AM | #5 |
Rep 668
I mean as long as you don't hear valve tapping (the early signs of a hydraulic lifter on its way out) you're good. What typically kills them is crappy oil/ taking too long to change the oil. Rarely do they go bad from mechanical failure on these engines.
