2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes What's the risk?
      05-10-2014, 01:13 PM   #1
deepat04
Drives: 2019 M550/2019 330 M Sport
What's the risk?
Had new wheels and tires installed last night. The shop that did my install, put 245/35/20 front on 8.5in wheel offset 35
And a 275/35/20 rear tire on a 20x9.5 wheel offset 37
I requested 275/30/20 rears.
Called the shop and they said they will swap out the rear tires for the originally requested size. So no issues there, my question is, what is the risk of running this set up?
245/35/20f 275/35/20 rear?
I ask the question because I do like the added sidewall protection for the wheels, but if their is any risk ( even minor ) involved with this set up I will swap the rears out for the proper size first thing Monday.
      05-10-2014, 03:07 PM   #2
Dan1416
Dan1416's Avatar
39
Drives: 2013 528 x-drive
If it's not xdrive then there is no risk. If it's xdrive then you may cause some damage since the diameters are off
      05-11-2014, 06:20 PM   #3
deepat04
Did some research the car's rolling diameter is off by 3.76% over stock which above the 3% threshold. Will be changing tires Monday.
      05-12-2014, 01:20 AM   #4
EV0LVE
EV0LVE's Avatar
41
Drives: F10 535i SG
If you want more meat on the tires, swap the rear to 285/30, and you'd still be on spec.
I don't know what risk you'd run into, but I'd rather just do it right and not worry. I'd hate to find out what the risk are after the fact.
Cheers!
      05-12-2014, 02:17 PM   #5
VMRWheels
VMRWheels's Avatar
2038
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
For the most part, it's risk of rubbing and potential brake failure. Just swap them out for a shorter sidewall and you should be good.
Cheers!
Good motto!
      05-12-2014, 08:24 PM   #6
deepat04
Good motto!
Done.
