2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum OEM rear bumper conversion (base to M) parts list
      06-03-2013, 07:36 AM   #1
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
Now both the front and rear are complete.
Link for parts list for front bumper:
http://f10.5post.com/forums/showthread.php?t=806000
Here's the parts list for the rear:
Bumper trim panel, rear, M (part must be identical to) 51128048593
Cover, bumper, rear M DARKSHADOW 51127906283 (commonly called diffuser)
Guide, bottom center M 51127906845
Guide, center rear M 51127906292
Reflector, rear left 63147842955
Reflector, rear right 63147842956
Cover, tow fitting, rear, 51127240133
      10-02-2013, 11:49 AM   #2
Boss330
Boss330's Avatar
What is the difference between Guide center, Rear (pos 8 below) part # 51127906292 and # 51127184766?
The first # is for the M-sport and the second is for the std rear bumper. Are there any physical differences that necessitates changing to the M-sport version?
      10-02-2013, 01:55 PM   #3
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
I did not compare them side by side, so I do not have a definitive answer. Is it possible that the M Sport bumper slightly deeper and needs a slightly larger connective piece?
Regards,
MWPos
      02-15-2014, 11:43 AM   #4
Lazz818
Drives: f10 535i
How much did full conversion cost? (not including labor)
      02-15-2014, 12:27 PM   #5
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
For the rear bumper cover and other parts, my expense was about $900. The paint and installation (labor) cost another $300. I don't know what the breakout is between labor and materials for the paint and install as it was a single charge.
Regards,
MWPos
      02-15-2014, 07:06 PM   #6
dreamspeed
dreamspeed's Avatar
Drives: 6MT
To the untrained eye the regular, msport, and ///M bumpers look the same but IMHO the ///M bumper looks WAY better
      02-16-2014, 11:06 AM   #7
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
Yep, minor differences on the rear compared to the dramatic changes for the front bumpers. For the rear, from base to M-Sport, the changes are the rear reflector mounting being higher up the bumper and a removable diffuser. The removable diffuser seems to be a common reason for the change from base to M-Sport. Lot's of folks use that opportunity to install quad-tip exhaust systems and the ///M diffuser or something patterned after it.
Regards,
MWPos
      04-02-2015, 02:37 PM   #8
flaviu52
Drives: Bmw F10 535i Bmw F13 650XI
Here is my conversion from Non M bumper to M5 bumper with quad exhaust
http://f10.5post.com/forums/showthread.php?t=1110496
      05-07-2015, 01:19 AM   #9
hamanncheese
Drives: F80 M3, F15 X5
I just completed the rear M-sport bumper swap and part 51127906292 (number 8) is definitely not needed as the bumper had no issues mating to the factory part. Hope this helps someone out in the future.
Time to return the part back to the dealer...
2016 M3 Mineral White | 19" Black 437M | DCT | Cloth
| Vorsteiner tips | Osram CBI | Llumar CTX 30 | Emmanuele Design springs | Macht Schnell 15/12mm spacers
2017 x5 xDrive40e Carbon Black | M-Sport | 20” Silver 469m
| Osram CBB |
      05-07-2015, 06:09 AM   #10
DLerner
DLerner's Avatar
Drives: F10 535, X164 GL550
Looks great. M Sport rocker panels next? Are you running M351 wheels or something else?
