05-06-2012, 09:49 PM | #1 |
Rep 432
Drives: F10 535i M-sport
JB3 threw CEL HELP!
I was driving on the freeway and the CEL showed up. I looked at the vehicle status and all systems are ok, I checked under the hood and everything is plugged in. Not sure what it is. Any help would be great
05-07-2012, 08:30 AM | #3 |
Rep 8,835
Best bet is to contact Terry at Burger Motorsports. You might be able to get any autoparts store to pull the code for you for free. Without the code it could be anything and impossible to diagnose.
Alan
05-07-2012, 10:22 AM | #5 |
Rep 3,834
AutoZone does free diagnostics. Just show the guys where your OBDII connection is located, and they can pull the code(s). Once pulled, call BMS for support.
Once catch is, I don't think a standard BT scanner will pull codes on N55s (it's worth a shot). |
05-07-2012, 11:16 AM | #6 |
Rep 432
05-07-2012, 01:24 PM | #7 |
Rep 645
Please keep us posted.
I had engine malfunction 2 weeks ago. I was lucky to be able to drive it home that day. Couldn't start the engine after that. I immediately unplugged the cable, took the kit out and put everything back to original. Called BMW and had them tow the car the next morning. BMW asked me if I had any performance tune on the car. I said "NO". They said the computer needs reprogramming/update. Problem fixed and they returned the car to me that same day. I wonder if it had anything to do with the JB3. I plugged the kit back in and now only adjust the boost to 4.0 instead of 4.75 I had before. |
05-07-2012, 05:36 PM | #8 | |
Rep 432
05-08-2012, 08:14 PM | #9 |
Rep 432
05-08-2012, 09:23 PM | #11 |
Rep 432
05-09-2012, 08:31 PM | #12 |
Rep 432
Took the tune off today, no more light. mission complete
05-09-2012, 09:42 PM | #13 |
Rep 5,040
those codes are probably still stored for BMW to find - I would consider getting them erased by a shop with a GT1 scanner or something else that can delete shadow codes
05-10-2012, 08:30 AM | #14 | |
Rep 432
05-10-2012, 09:44 AM | #16 | |
Rep 966
I emailed Bavarian Technic last week and they said they are working on support for the F10, but don't have a release date yet - they mentioned likely by year end. |
05-10-2012, 12:41 PM | #17 | |
Rep 432
05-10-2012, 12:42 PM | #18 | ||
Rep 432
05-10-2012, 02:45 PM | #19 | |
Rep 966
If you took it out and aren't having problems I wouldn't bother bringing it in - just work with Terry to resolve the issues if you're interested in re-installing the tune. |
05-10-2012, 02:45 PM | #20 |
Rep 42
Nah I brought mine in and simply removed the harness and played dumb. No one asked me anything. They said there was a malfunctioned mass air flow sensor and the bov actuator stopped working. I have a real funny feeling at 4800 miles, this jb3 is pushing the car too hard and thus all the CEL people are getting. We all know the charge pipe flimsyness too. I'm of the opinion things will start falling apart and fast if you boost over the stock range the car expects. You can thank crappy made parts. Cheers
05-10-2012, 04:50 PM | #21 | |||
Rep 87
05-11-2012, 03:21 PM | #22 | |
Rep 645
Like Oldrandomguy did, I also took the kit out and played dumb. They just update/reprogram the computer. Problem fixed. I immediately reinstall the kit set it at 4.0 (was at 4.75 before). It has been 2 weeks. No problem so far. SHOULD I BE WORRY?????? |
