2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 550i Sport -- under-tired?
      06-20-2010, 10:59 AM   #1
MBrown1003
Eight Bimmers and counting
Drives: 2014 F10 M5
I got a chance to drive a 550i with sport + dynamic handling packages yesterday. In one of the other threads here, someone called it a rocket. Agreed. I really liked the head-up display, too, though I wish it was more like the one in the E60 M5 I drove at the Performance Driving Center. That one had a green/yellow/red arc representing revs, which would be helpful for those of us planning for manual transmissions.
BUT ... the reason for this thread...
I took a couple of sharp corners "enthusiastically". The tires squealed like crazy. I wasn't driving especially aggressively, just taking an exit ramp with brio. It felt to me like the tires (those <bleep> RFTs) were just completely overwhelmed.
What have others found?
2014 F10 M5
Previously...
Threes: '08 E90 M3, '07 E92 335i,
Fives: '11 F10 550i, '02 E39 M5, '00 E39 540i/6, '97 E39 528i, '92 E34 525i
Others: VW, MBz, Peugeot, Toyota, Olds
      06-20-2010, 11:21 AM   #2
dilsere2
dilsere2's Avatar
Drives: 2013 E92 M3
It was me who said 550i was rocket...I picked up my 550i last week and already put 400 miles on it ..I don't hear any sweak noise on RFT
Current Driving - 2020 M2C
      06-20-2010, 02:08 PM   #3
carl_d
carl_d's Avatar
Drives: E90 335i M-Sport N55 6SP Nov10
underinflated tyres!?
2010 E90 335i M-Sport, 2005 E90 325i M-Sport, 2003 E60 520i, 2002 E46 330i Sport II, 2000 E46 325i Sport I, 1999 E46 318i, 1998 E46 323i SE, 1996 E36 323i SE, 1996 E34 518i, 1995 E36 320iA, 1994 E36 316i
      06-20-2010, 02:39 PM   #4
raleedy
Drives: 2016 228i 6-speed
US cars all have TPMS, so that's not too likely. What we do have here is a big, very heavy car and the associated forces.
      06-20-2010, 05:14 PM   #5
carl_d
carl_d's Avatar
TPMS only works if its set correctly!!!
      06-20-2010, 05:55 PM   #6
raleedy
And it most likely is.
      06-20-2010, 07:28 PM   #7
MBrown1003
Drives: 2014 F10 M5
It's been a while since I had my E39 M5, which was no lightweight, but I *think* I was able to take that curve at similar speeds in that car, with no protest from the (non-RFT) tires...even the winter tires.
It'll be a very wacko situation if the 550i feels better on winter [non-RFT] tires!
2014 F10 M5
Previously...
      06-20-2010, 09:59 PM   #8
enigma01
Fight On!
enigma01's Avatar
Drives: e92 M3; g30 530e
It most likely is due to the weight of the car (4300lb+).
      06-20-2010, 10:12 PM   #9
ibimmer954
Drives: '23 i4 M50, '15 M3, '18 911
I've driven my 535i with Sport+ZDH+IAS aggressively on twisty roads a couple times and I haven't heard any complaints from the tires. The car just remains stuck to the road. I'm still amazed by the handling given how large and quiet the car is. I'd imagine the U.S. 535i and 550i have the same tires.
Wait, do you think they were squealing from the cornering or acceleration? Or were you doing both at the same time. I guess tight cornering plus acceleration could cause some complaints from the tires.
      06-20-2010, 10:52 PM   #10
MBrown1003
Drives: 2014 F10 M5
Mostly cornering. It's a tight exit ramp that makes a 180-degree turn. It's not a classic cloverleaf -- tighter radius than that.
2014 F10 M5
Previously...
      06-21-2010, 02:48 AM   #11
carl_d
carl_d's Avatar
Nevertheless its should be checked.
      06-21-2010, 09:29 AM   #12
raleedy
Indeed. BMW and its dealers are well known for setting up driving demos using cars with four equally flat tires.
      06-21-2010, 10:25 AM   #13
carl_d
carl_d's Avatar
Same here, I've never had my car back from any dealer or tyre depot with correct inflation - never!
      06-21-2010, 12:31 PM   #14
ibimmer954
When I got my 335i I couldn't figure out why the steering felt strange until I checked the tire pressure. It was 24-26 psi on all tires! I drove that way for a couple weeks before I got suspicious. The TPMS didn't complain since it was clearly reset to "normal" on those low pressures.
After I brought the 535i home, the first thing I did was check the tire pressure. They were 34 up front and 37 in the back. Exactly what they should be. So at least the dealer didn't mess up this car.
