2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Cover Art with 520d
      07-04-2012, 09:38 AM   #1
GazRad
Drives: 520d SE Auto
Cover Art with 520d
I've just taken delivery of a 2012 520d SE with the standard audio/idrive gadgetry. I hoped/thought that the Cover Art on my iPod would display on the monitor, but I can't get it to. Does anybody know if this is supported?
      07-04-2012, 10:14 AM   #2
sj_carr
Drives: 2021 540i MSport
Works on my 550i - using the iPod connector.
How are you connecting?
      07-04-2012, 12:52 PM   #3
snj1013
Drives: 2011 528i
If not using an iPod, you may need to imbed the jpeg into your mp3 files. Google mp3tag, it is freeware software to help with this.
      07-04-2012, 02:00 PM   #4
A900ss
A900ss's Avatar
Drives: 2012 520d Touring
Also works fine on my 2012.
I'm connecting a 5th gen IPod via USB cable to the USB connector in the armrest
      07-05-2012, 09:07 AM   #5
darrko
darrko's Avatar
Drives: 2016 M5 Comp. Ed.
2016 BMW M5  [0.00]
I've noticed that sometimes it may take a few seconds after the songs starts playing for the cover art to show up, and also most of the time the image is very low-res instead of the crisp image you see in the promotional images put up by BMW. I would post photos but I am traveling, will do that when I get back.
If you already have iPod integration as an option for your vehicle you should check the music file itself and confirm if the cover art is even part of the file info. If the cover art displays on your iPod then it should also display on the car screen.
Current:
2012 520d
2016 M5 Comp. Ed.
2020 Porsche 911 Carrera S (retired)
2023 X5 xDrive45e
      07-06-2012, 01:34 PM   #6
en1gma
en1gma's Avatar
Drives: G03 X3
I have Jan 2012 build 520d with prof media (but not the Internet option). I connect my iPhone 4 using the standard Apple white USB lead via the connector in the arm rest and it works fine. Every time there is a track change, it goes back into a 'track detail' view for some seconds before showing the cover art again.
I find that where iTunes had found the cover art for CDs I had ripped, the picture is pristinely clear. Where I have copied and pasted cover pictures into iTunes from other sources (because iTunes could not find the cover art) then these can be ropey depending on the quality of the source...
Couldn't tell before on my older iPod Touch, but you can on the retina screen on the iPhone 4!
      07-06-2012, 03:33 PM   #7
Bimmernerd
Bimmernerd's Avatar
Sweden
Drives: 530dM xDrive F11 2012
And my problem is that the iDrive screen every once in a while shows the wrong cover art, when you change track the cover art does not change...anyone else have this problem? I use iPhone 4 (iOS 5.1) connected through USB, F11 built in Nov 2011...quite annoying
      07-07-2012, 06:50 AM   #8
en1gma
en1gma's Avatar
Drives: G03 X3
You might want to check in your iTunes library that all tracks within an album have the right cover art associated.
Typically, when using an iPhone or iPod, you never really look at the cover art after you've chosen what you want to listen to. However, in the car, the cover art is always visible...
      07-07-2012, 09:18 AM   #9
Bimmernerd
Bimmernerd's Avatar
Sweden
Nope, there is something wrong with the car. The iPhone always shows the right cover art...
      07-27-2012, 02:05 AM   #10
Dandle
Drives: G05 X5 M50i
Did you get a fix for this? My iPod shows the correct cover art but iDrive never displays any.
      07-27-2012, 01:51 PM   #11
Bimmernerd
Bimmernerd's Avatar
Sweden
No I have not bothered to go to my dealer and get it fixed...will make a change from iPhone 4 to Samsung Galaxy S3 soon, maybe it works better.
I discovered some weeks ago that it not only displays the wrong cover art but once in a while also the wrong track name/artist...quite amazing how badly this is implemented on a 60 000 EUR car
      07-28-2012, 04:02 PM   #12
Dandle
Drives: G05 X5 M50i
Right I found the fix for my issues. It was the BMW y-lead which won't show cover art from the iPod, if I use the original apple iPod lead with just USB it plays the songs and shows cover art.
      07-31-2012, 01:51 AM   #13
Bimmernerd
Bimmernerd's Avatar
Sweden
I have always used the original iPhone USB cable...obviously the cable is not the source of the problem in my case.
      07-31-2012, 04:49 AM   #14
islandnipper
islandnipper's Avatar
Drives: MY 2012 F10 520d SE
Yep, that's exactly it. There was quite a lot of chat about the problem here, when the cover art feature appeared for our F10/F11 orders. The Y-lead not only is no longer required, it doesn't work (I suppose those of us that moved from E60/61s just wanted to justify our earlier £45 expense of the special lead!).
The standard iPod lead is the correct connection method and you should now be fine.
      07-31-2012, 06:27 AM   #15
Bimmernerd
Bimmernerd's Avatar
Sweden
As you saw in my previous post the solution to my problem with incorrect cover art and/or track name/artist is NOT an iPhone USB cable...
      07-31-2012, 08:48 AM   #16
islandnipper
Yes, sorry Bimmernerd, I was referring specifically to Dandle's post then...
I remember that when I ordered my MY2012 car (del Oct) there were a lot of iPhone/iPod connectivity requirements that had to be added to get everything to operate correctly. The dealer sorted it all out in the end without any extra input from me, so cant remember the part numbers, but the order referred to "media connectivity". I wonder whether there is some part missing in your build that a dealer may be able to help with?
