2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 2014 n63tu edition BMS stage 1 DYNO #s
      02-08-2014, 09:15 PM   #45
scott135i
scott135i's Avatar
Drives: 2020 X5 M50i
Originally Posted by Seattle335 View Post
Looked on the BMS site - I could not find anything about the Stage 2 for the N63 - is this still in beta? is Stage 2 just a download?
In beta for at least the next few weeks/months. More likely weeks...
It's a new control box and 8 new wires you need to install into the harness and into the actual ECU by removing the connectors... its a pin out install.
BMS has posted a video, go to N54tech for it.
      03-06-2014, 08:20 PM   #46
wzj519
Drives: 2017 M3 COMP PKG
Hey Scott, how is your n63tu engine with BMS tune going so far?
I am still waiting to put it on once spring comes to Canada.
BTW, since your car has identical tranny and engine as mine.
May I ask you do you have any jerky shift feeling when the car is cold?
Also what's your engine idle speed? Mine idles at 500RPM when A/C off, and it causes the vibrations of the the car.
Just want to know is my car performance normally. BTW, mine is a 13 650GC.
2012 X6 35I (Gone) 2013 650 GC (Gone)
2014 M5 Comp PKG (Gone)
2015 X6 50I (Gone)
2017 M3 Comp PKG 2017 MINI JCW
991.2 GT3 (coming)
      03-06-2014, 09:20 PM   #47
badblack550xi
badblack550xi's Avatar
hes car is a N63 none TU
2011 550i RWD 60-130 7.35
      03-06-2014, 09:21 PM   #48
scott135i
scott135i's Avatar
I have a 2013 550XI which has the older non-TU engine, so can't compare apples to apples. You'd need to compare with 2014+ 550s
      05-29-2014, 09:05 AM   #49
badblack550xi
Originally Posted by combatbmw View Post
racegas dont couunt. beeshboy
just an FYI i ran 12.1 on 93 and 11.9 with NOS octane booster ($9 at wall mart) no race gas.
      06-19-2014, 01:00 PM   #50
Deslypher
Drives: F10 550i
When mode are you in when you do your runs? Are you in Sport+ and shifter to the left? do you let the CPU autoshift for you or are you paddle shifting? Just curious to see what is the best way to run my car.
TIA! I know
      06-20-2014, 01:33 PM   #51
badblack550xi
TIA! I know
Sports + to the left... i let the car shift don't really make a difference down 1/4 60 foot is more important in our cars.
      06-20-2014, 03:53 PM   #52
Deslypher
Drives: F10 550i
thanks
      08-11-2015, 02:05 PM   #53
doppelganger1
Drives: 2013 550i M Sport/DP/BMS S1
Why N63Tu loses hp/tq at higher rpm
I just happened on this thread so I'm way late to comment, but I believe I know the answer to the riddle of why the N63Tu motors lose hp/tq at higher rpm: The cause is the Valvetronic head, which is on the N63Tu but not the N63. The Valvetronic head has an additional cam and finger followers that modulate the intake valves to regulate throttle (fuel intake). This is a complex arrangement and at higher rpm wot the finger followers tend to "float" which reduces throttle response, increases fuel consumption and also increases CO and NOx emissions. There are two solutions: (1) increase the spring rating (tension) on the finger springs so they can keep up with the rpm; however, this adds friction which decreases hp/tq slightly, increases fuel consumption and increases engine wear, or (2) have the ECU reduce power (hp/tq) at higher rpm so the finger followers are less modulated and can keep up. BMW chose the latter (2) on the N63Tu motor as the lesser of two evils. The S63Tu also has Valvetronic, but the engine is much more powerful and of higher quality (wear resistant), so BMW used solution (1) which does not result in hp/tq dropoff at higher rpm.
1320racer135.00
      11-23-2017, 06:23 PM   #54
1320racer
1320racer's Avatar
135
Drives: 2013 BMW F10 M5
Has all of this info been confirmed?
      11-28-2017, 11:10 AM   #55
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
I asked a guy who fixes n63tu/s63tu engines and he said spring rates are same between the n63tu/s63tu engines, so I think it's a false assumption
He said due to high EGT power is reduced at high rpms, but I'm not sure if that's true either
      08-04-2019, 06:42 PM   #56
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
I know this is long dead, but from the dyno graphs it looks like small turbos reaching their peak airflow/ efficiency.
