10-28-2015, 11:06 PM | #1 |
Rep 208
Non-OEM Battery
Looking to see if anybody here has gone with a non-BMW battery for their car and what their experience has been like. I think my battery is going to need replacing soon and I'm definitely not wanting to pay $400 or $500 for one from BMW. Please share any info you may have.
10-29-2015, 02:58 PM | #2 |
Rep 767
I was in your situation about two months ago. Was a hassle trying to find one to be honest so I just ended up buying one from BMW for around $280 or so, and taking it to an Indy BMW shop to have it installed and registered. Pricey but saves you the hassle honestly.
10-29-2015, 04:29 PM | #3 | |
Rep 208
10-29-2015, 04:52 PM | #4 | ||
Rep 767
11-17-2015, 03:12 AM | #5 | |
ZEROdoubleZERO
228
Rep 659
I paid $549 to have my battery replaced in March by the dealer which included the registration. The 550 uses a 105Ah AGM and the 528 is 90Ah AGM I would just get it form the dealer, we have too much electrical to skimp on the battery. Also I was just like you and didn't want to pay the dealer but I couldn't find a suitable replacement anywhere, if I did they wouldn't ship. The battery in our car is a beast of a battery and not what you would find in a Honda or even a full size Chevy truck, it's weighs 65lbs and has more power than most car battery's do. So don't feel like your getting screwed it's a bad ass battery. |
11-17-2015, 06:32 AM | #6 |
Rep 1,873
Dealer batteries aren't any better than a high quality alternative. The NA dealer network does not use the same manufacturer that the German factory does. There are only a few companies that make batteries and hundreds that throw their sticker on them.
A couple of years ago my research concluded that East Penn/ Deka makes some of the best batteries out there and they make a line of OEM perfect batteries for Euro cars. It doesn't matter whose sticker is on it, it's who makes it Get the proper size and shape replacement AGM battery and make sure to get it registered when you replace it and drive on.... |
11-17-2015, 11:29 AM | #7 |
ZEROdoubleZERO
228
Rep 659
This is the closest AGM battery I could find and it out specs the stock battery, these are the best batteries you can get and they are not made by someone else. You can get a post kit for it to put your stock connectors on it.
Link, http://skyhighcaraudio.com/xs-power-xp3000/ |
11-17-2015, 03:23 PM | #8 | |
Rep 1,873
Regardless, make sure that whatever you choose has the same plastic shaping that will work with factory hold down hardware and, obviously, terminals |
11-17-2015, 04:06 PM | #9 |
ZEROdoubleZERO
228
Rep 659
[QUOTE=Surly73;18926723]Not sure about the "not made by anyone else" comment. Not many people can tool up to build a battery factory.
Regardless, make sure that whatever you choose has the same plastic shaping that will work with factory hold down hardware and, obviously Cool story Last edited by Teddylongtooth; 11-17-2015 at 04:18 PM.. |
11-17-2015, 05:07 PM | #10 |
ZEROdoubleZERO
228
Rep 659
Using info from the battery expert in this thread I was able to find this battery from deka.
Link, http://www.batteriesasap.com/9agm95r.html |
11-19-2015, 02:12 PM | #11 |
Rep 208
I still haven't gotten around to replacing my battery. It is definitely close to needing it though. I had to give it a good charge before having it flatbedded to the dealer yesterday for what I think is bad injectors. I am definitely going to go non-OEM and have it registered by an independent shop. I have actually had pretty good luck finding a number of made-for-our-cars replacements. My intentions were to register it myself with ISTA/D (Rheingold), but I have been super busy lately and haven't had the time to get the software working on my computer yet.
01-07-2018, 04:04 PM | #12 |
Rep 244
The battery on my 535i is limping along on it's last legs. The recent cold weather is not helping. Can anyone confirm what size/shape battery we have? It seems to be an H8? The OEM battery is apparently an Exide (at least in the US), which can be had at Home Depot of all places.
For reference, I have a base model 535i. The battery in there has 800 cold cranking amps (CCA), and 80 Ah.
Mike
'04 330i ZHP '11 535i |
01-07-2018, 04:21 PM | #13 | |
Rep 5,362
01-08-2018, 06:31 AM | #14 | |
Rep 1,873
If you change the capacity (Ah rating), you should get the car coded for the new capacity. This is the same as any other coding (fold mirrors, no seatbelt warning, auto window close enabled etc...). You can change the coding for the battery capacity at any time, but I would personally try to do it right before registering. If you replace the battery, you must register the new battery. This tells the car that you've replaced it with a new battery, and to reset all of its learned trending information about the age and performance of the battery. If you're DIYing, bench charge the new battery before installation if you can. As for brand - I've grown to like East Penn/Deka batteries, which are branded by many other battery brands. They fit well, perform well, don't leak (doesn't apply to AGM) and last a long time. Deka has an "Exact fit OEM" line for Euro cars: http://www.eastpennmanufacturing.com...Flyer-0379.pdf A dealer locator will give you an idea where you can buy batteries made by East Penn - thought they may be re-branded by whomever. |
01-08-2018, 10:07 AM | #15 | |
Rep 244
Mike
01-08-2018, 02:23 PM | #16 |
Rep 1,873
01-19-2018, 12:23 PM | #17 |
Rep 18
FYI - BMW is running a $30 Mail in Rebate until 2/15/18 on batteries purchased at the parts counter or installed by the service dept. Check BMWRebateOffers.Com
Believe it or not, I got a battery from my local parts counter for $168 (after BMWCCA discount). Factor in the rebate and you really can't go wrong. I performed the registration myself with Schwaben's BMW/Mini Scan Tool (ECS). |
01-24-2018, 09:10 AM | #18 | |
Ninjapotamus
26
Rep 320
