2010 2011 BMW 5 Series Forum F10 2015 F10 535i vibration 75+ mph |
08-11-2022, 02:38 PM | #1 |
Rep 74
So I have been trying to diagnose a vibration. It occurs mostly between 70 and 80 mph, worst at around 75. I bought 4 new michelin tires, when I bought them, i was told both right side wheels were bent so i replaced them with brand new wheels. tires were all re balanced and roadforced. Road force numbers were 9, 11, 14, and 18 i believe. This is the strange part..... when its 65-70 degrees outside, the car has almost no vibration. When its 85-95 outside it shakes alot. Anny ideas? Car has 88k miles.
08-11-2022, 10:08 PM | #2 |
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Maybe a weight came off but vibration at specific speed is usually a balancing issue. Assuming you don’t have spacers?
08-12-2022, 03:33 AM | #3 |
Rep 623
Drives: F10 530d M Sport, E87 118d M
There are numerous threads on this subject - search for vibration. The issue appears to be very difficult to identify and resolve. My car suffers the same issue - vibration at about 72 to 75 MPH. I've decided to live with it and drive at 70 or 78 MPH.
F10 530d M Sport, September 2012 Individual Amazonite Silver, Oyster Dakota Leather, Auto, Nav Pro, Bluetooth + USB Devices, Expanded BMW Online, Comfort Seats, Sunroof, Sun Protection Glass Individual Satin Walnut Honey Brown Trim Interior Inside/Outside Mirror with folding and autodip, M Rear Spoiler
div1ne21.50 |
08-12-2022, 07:30 AM | #4 |
Rep 74
no spacers, factory 351m wheels and factory size tires. It is possible that its thrown a weight but they have been rebalanced 3 times so far.
My issues doesnt go away above a certain speed, it just becomes less noticeable but still there otherwise i would do the same thing lol. |
08-12-2022, 09:53 AM | #6 |
Rep 74
08-12-2022, 10:31 AM | #7 |
Rep 639
Look at your front thrust arms and consider replacing. The bushings tend to go quickly and make the issue worse.
Also look for a highly recommended wheel shop to rebalance. I had to go to three different shops to eventually get my wheels balanced properly and eliminate my vibration issue. |
08-12-2022, 01:11 PM | #8 | |
Rep 74
08-12-2022, 03:07 PM | #9 |
Rep 951
I have a weird vibration that is most noticeable at 75-80MPH AND specifically in 8th gear where it manifests most, and specially on slight inclines.. almost a resonant/repeating vibration.. I've already gotten the wheels straightened, control arms swapped, balanced/rotated, and rear differential mounts replaced. Also had the transmission fluid changed but 0 affect thus far..
08-15-2022, 12:38 PM | #10 |
Rep 74
So I did some poking around. I jacked up the front of the car and cant seem to find any play in anything. What I did notice is that when I spin the wheel, I can visibly see the top of the tire moving up and down as it spins. I know that a little run out in a tire is normal but it seems excessive to me. I ordered one new tire and i am going to swap it out and see if anything improves. This particular tire had a road force of 39, I rad them spin it 180 degrees on the wheel and it went down from a 39 to an 18 (other tires were 9,11, & 14). I have a month to kill trying on my own before the dealership can look at it.
08-15-2022, 05:29 PM | #12 |
Rep 38
Solved a similar vibration in my 535i by replacing the engine mounts. The old ones weren't collapsed nor visibly damaged, but the car got much smoother at highway speeds.
This was after all new Lemförder arms, new 434M wheels, Michelin tires, etc. Drives great now, even with a torn differential mount and some small cracks in the flexdiscs. Those are next on the list. |
08-18-2022, 08:04 AM | #13 | |
Rep 68
08-19-2022, 03:48 PM | #14 | |
Rep 965
08-21-2022, 04:54 PM | #15 |
Rep 13
I had a few issues that lead to my higher speed vibration. One was an out of round wheel. New tension arms also helped, and the final improvement was new struts/springs. It now rides fairly smooth for a 9 yo car, though unfortunately not perfect.
08-23-2022, 07:33 AM | #16 |
Rep 74
Well I still have an appointment with the dealer on 9-14, hoping i can get it resolved before then. Update: I noticed the longer im on the road and the hotter it is outside, the worse it vibrates. i let the tires down to 29 psi and it rides smooth until ive been on the road a while and pressure gets back up to around 33 psi. Took that info to the tire shop and they agreed to replace all 4 tires at no cost (via the Michelin promise plan/ 60 day guarantee). Hopefully this will fix my issue, just waiting for the tires to come in now.
