09-14-2022, 03:09 AM | #1 |
Rep 167
rear sway bar eibach
Hi,
I just installed the eibach sway bar front and rear.. after install the rear was bumpy af, itll just bounce on the rear for whatever on the road.. even on acceleration itll jump. the front is ok, but I had to swap to oem on the rear.. any fix to this issue? |
09-14-2022, 11:28 AM | #3 | |
Rep 167
Do you have any pics of the correct install? Waiting for Koni special active shocks in december, after that install I will put the sway bar back and test. |
09-14-2022, 11:40 AM | #4 | ||||
Rep 598
No pic but the bend where the bar turns outside the bushing, it should "loop" around the rear control arm. If it is upside down, the bend will face down and sit on the control arm. |
StradaRedlands4941.50 |
09-14-2022, 12:23 PM | #5 | |
Rep 167
Thanks for your feedback, will reply in 3 months when parts arrives..
I've read in a few post that for some folks the ride is too harsh, but this is outrageous.. Quote:
09-15-2022, 06:00 AM | #6 | |
Rep 1,873
It was almost certainly installed incorrectly as other posters have stated. I've been running the H&R 20mm rear bar (same thing, just blue) for years and wouldn't want to be without it. |
10-04-2022, 10:42 AM | #8 |
Rep 1,126
If the car is on stock suspension, it will be a bouncy ride with after market sway bars. I have tried several combinations of suspension setup. Best balance of comfort/sport is Msport sway bars & after market coilovers.
