2010 2011 BMW 5 Series Forum F10 How often do you get the engine mounts replaced? |
06-07-2018, 05:21 AM | #1 |
Rep 392
My car is a 2012 F10 (manufactured Nov 2011). Back in end of 2014 I got the engine mounts replaced as the car was driving a bit rough...the shop that inspected it said the mount was worn-this was when the car barely had 8k miles.
After the mounts were replaced, sure enough the car felt just like New and extremely smooth. Right now the car is at 15.5k miles and I can feel the car shaking slightly when I start it in the morning and otherwise whenever I’m stopped at a traffic light. Do these mounts only last 3 years? Regardless of how much the car is being driven? Or less driving makes it worse? My car has the n20 engine. Thanks in advance! |
06-09-2018, 08:36 AM | #5 |
Rep 14,522
Motor mounts deteriorate over time just like bushings and what not but not that fast
06-10-2018, 01:34 AM | #6 |
Rep 392
Well I Guess since motor mounts are supporting the weight of the engine even when the car is not being used...it’s not just the mileage but the time factor also. Since I drive 7-8 miles in 3 years...it’s not that outrageous. Will be taking my car in to get them inspected.
06-10-2018, 06:32 AM | #7 |
Rep 659
Since you insist, go for it.
You have been around the forum, how often have you seen anything about motor mounts? |
Big Mexican Women101.50 |
06-10-2018, 09:17 AM | #8 | |
Rep 15,858
06-10-2018, 10:14 AM | #9 | |
Rep 343
06-10-2018, 11:06 AM | #10 |
Rep 392
When my car was 3 years old and had 8k miles...even I was surprised that motor mounts had to be replaced. When they took out the mounts and showed me how it compares to new ones...mine was indeed much more depressed. This time around I don’t know if it’s the mount again or something else. Will update once I get it checked out.
08-26-2019, 01:36 PM | #11 |
Rep 392
Having very rough idle on cold mornings
on n57 535d f10. suspect engine mounts need replacing at 97,000. Suggestion above to run smooth running control is not a bad one. |
08-26-2019, 07:04 PM | #12 |
Rep 1,261
I’m at 135k. I assume they are original as I do get a slight vibration at idle. Actually expected it to be worse at this mileage. Good thing is FCP sells the mounts pretty cheap.
08-28-2019, 05:37 AM | #13 |
Rep 866
Twice in over a million miles did I need motor mount repair: once with my 1986 944 which had a special fluid filled mount in a highly unbalanced engine, and another time with my daughter's 2003 1.7l Civic which didn't really help the inherent unbalanced engine.... I keep cars at least 100,000 miles or so, some to 200,000 miles.
08-29-2019, 07:02 AM | #14 | |
Rep 1,254
I was surprised to see this posted
08-30-2019, 05:39 AM | #15 | |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
https://www.realoem.com/bmw/enUS/sho...diagId=22_0153 Also diesels get rougher with age it’s kind of typical. Replacing these mounts at less than 70k miles is not unheard of they do fail. Other source of rough running is glow plug failure. |
08-30-2019, 05:42 AM | #16 |
Rep 1,146
Drives: F10 550i
One other thing to check besides engine mounts are rear subframe mounts as bad ones there can transmit a lot of diesel vibration. Diesels just aren’t as smooth running and bmw did a lot to isolate the vibration. But as bushings age more can be transmitted into the car. By no means are bmw diesels rough. You should sit in my f450 with it’s 7.3 powestroke,,, You get a constant massage.
08-30-2019, 02:06 PM | #17 |
Rep 5,357
08-31-2019, 07:46 AM | #18 | |
Rep 1,146
Drives: F10 550i
They’re on longer than you think. They’re on until the engine achieves operating temp so they’re on several minutes after you start the car. That’s why they fail when the thermostats fail on the diesels as the glow plugs never turn off because the engine never achieves operating temp. Thermostats fail open. Anyway they run for quite some time after a cold or below operating temp start and if one is bad it can cause rough running due to poor/no combustion in that cylinder. I’ve experienced it on multiple diesels. You know it’s really bad when you see white smoke out your tail pipe, as the diesel is going unburnt out the exhaust. |
Pierre Louis157.50 |
08-31-2019, 07:42 PM | #19 | |
Rep 5,357
