2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions BMW F10 Coding DIY (and other Fxx models)
      09-08-2016, 07:44 PM   #67
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
I don't think I've ever accessed that... Not sure if I know how!
HU_CIC > RADIO_WEATHERBAND: nicht_aktiv --> aktiv
      09-08-2016, 11:04 PM   #68
I've done that, but don't remember if it's an iDrive option or not.
      09-08-2016, 11:18 PM   #69
Almaretto
Almaretto's Avatar
2374
Yes. It should show up in idrive. Admittedly, I have only coded the function remotely so I have never seen it work in person.
      09-09-2016, 10:40 PM   #70
Thanks... I'll have to check that out.
Almaretto2374.00
      05-28-2017, 11:16 AM   #71
enes28
Turkey
Drives: Polo TSI
anyone knows how add sport + mode in F10 ?
      05-28-2017, 12:53 PM   #72
Almaretto
Almaretto's Avatar
2374
2TB VO coding.
      06-27-2017, 04:28 AM   #73
myszano1
Drives: f30
Hi there, I have tried to do some coding on F10 , but when I connect the car through esys there was no FEM_BODY module in SVT when I read the data?
Anyone know why?
      06-27-2017, 11:09 AM   #74
Almaretto
Almaretto's Avatar
2374
Anyone know why?
Because Fem_Body is only in F2x/F3x/F8x.
F01/F06/F12/F13/F10 & F25/F26 use FRM/CAS.
      06-27-2017, 12:10 PM   #75
myszano1
Drives: f30
Anyone know why?
Thanks for quick replaying.
so it's mean I'll find all things related FEM Body in FRM/CAS. right
      06-29-2017, 09:52 PM   #76
Almaretto
Almaretto's Avatar
2374
Most, if not all.
F2x/F3x/F8x has REM. Many of those are in JBBF on an F010.
There are Cheat Sheets and Launcher Cheat codes as well as BMW Coding Database for additional assistance.
      07-21-2017, 07:39 AM   #77
myszano1
Drives: f30
Most, if not all.
Any idea why I dont have access to following modules, see pict?
Try to inject cafd files but unsuccesfull.
Please advise.
      07-21-2017, 09:41 AM   #78
Almaretto
Almaretto's Avatar
2374
Please advise.
"Doesn't map to item" means you selected incorrect E-sys connection target. The ethernet errors usually mean you are not running engine to provide adequate power/communication to all ECU's.
      07-21-2017, 04:56 PM   #79
myszano1
Drives: f30
I allways connect esys by the vin, and chosing "vechicleinfoF020"
Please advise how I should connect f10, or f30, its any diffrent how to connect?
Thanks
      07-21-2017, 05:00 PM   #80
Almaretto
Almaretto's Avatar
2374
Thanks
F010 for F010
F020 For F3x/F8x
      07-23-2017, 04:58 PM   #81
myszano1
Drives: f30
Thanks
F010 for F010
F020 For F3x/F8x
What about other models, how to connect 1-7series?
      07-23-2017, 07:33 PM   #82
Almaretto
Almaretto's Avatar
2374
E-sys Launcher: Actual Series
E-sys Connection: Representative
It depends on if it is a 2016 or earlier 7 series. F001 for F001/F002 or S15A for G012.
      07-25-2017, 11:56 AM   #83
Bruno112
Croatia
20
Drives: 2014 F10 530d MSport
I have errors with my e-sys,can someone send me new download link with that tokens which i dont have.Thanks
      07-25-2017, 01:19 PM   #84
Almaretto
Almaretto's Avatar
2374
What errors?
Coding: Latest Software Links
      07-25-2017, 01:42 PM   #85
Bruno112
Croatia
20
I deleted program and forgot it.Thanks for link
      07-25-2017, 02:30 PM   #86
Almaretto
Almaretto's Avatar
2374
      08-07-2017, 07:31 PM   #87
TZ
Drives: 2011 535i xDrive, 2014 435i CO
I coded the Sport Display on my 2011 F10 535iX. It showed the units of kW for power and Nm for torque. When I floored the car, the torque meter maxed at 400 Nm which is about 300 ft-lb that matches my car's spec. Recently I coded the hp and ft-lb units for the Sport Display. However, when I floor the car, the max torque still reaches the the scale of 400 which now should mean 400 ft-lb. Am I missing something? Or the Sport Display is just imitative?
2014 435i RWD Convertible
Service Manual: www.newtis.info
Part: http://www.realoem.com
      10-29-2018, 04:43 PM   #88
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Link doesn't work
