2010 2011 BMW 5 Series Forum F10 F10 CIC Glovebox unable to read USB after map update |
06-09-2021, 06:09 PM | #1 |
Rep 7
Hi All,
Hope you are well !! Looking for your help !! F10 2012 Glovebox Port not detecting USB. Earlier it used to work and I have imported music from it which is still on drive. I updated maps to 2020-2 from this port last year and now when I am trying to import music its not working. I have tried 1/4/8/16 GB flash sticks with FAT or FAT32 format but not making any difference. Have anyone faced the same situation or any idea how to resolve it. |
06-09-2021, 06:49 PM | #2 | |
Rep 5,365
06-09-2021, 11:41 PM | #3 | |
Rep 7,484
The CIC with the USB (for data and music import) in the glovebox works slightly different than the BMWs with NBT & the singular USB in the center armrest. But you’ve gotta help us help you better…we are not there to see what your doing…so without details or steps that you’ve done…we can end up writing a bunch of suggestion that you’ve already tried. You do know that there are instruction built into iDrive. Right? You have a digital owners manual…it even has a search box that you can type something simple like “import music” and it will take you to the instructions where you can see if you are following the correct steps. I just did some music uploads the other day….and the process went easier with my 2014 f15 (NBT/USB in center armrest) than it did with my 2013 f06 (CIC w/data USB in glovebox) The CIC/glovebox USB port…the iDrive screen selection required a press of the OPTION button when there was nothing highlighted on the screen (which was different than with the NBT). But when I pressed the OPTION button, the selection to import from the glovebox USB illuminated. Again, pull up the instructions in the iDrive owners manual so that you know that you’re following the correct order. If that still doesn’t work…give us the steps you’re doing so that we can determine if there’s a step that you’re missing to get where you need to be. CIC has USB port in the glovebox for data & music file uploads to the car’s hard drive…the port in the center armrest is for playing music from your phone, USB thumb drive, or iPod/iPad or other device that has the proper music files on them: EDIT from the owners manual: To import music files to the CIC hardrive from a USB thumb drive, insert thumb drive into glovebox USB port…hit MEDIA button —>SELECT MUSIC COLLECTION —>PRESS OPTION BUTTON —> SELECT IMPORT:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 06-10-2021 at 06:42 AM.. |
06-10-2021, 01:22 PM | #4 | ||
Rep 7
06-10-2021, 01:27 PM | #5 | ||
Rep 7
I formatted 1/4 GB USB in FAT/ FAT32 and put mp3 files inside it. Then I connected to glovebox usb port. Tried to import data but it prompts to insert USB. But the port is definitely working as today I connected my phone to it and its charging so that means port is functioning properly. Same pen drive is not detected in console port as well. |
06-13-2021, 01:10 PM | #6 | |||
Rep 7
Finally I figured it out and able to resolve it. My pendrive had GPT partition which now a days most of the USB by default have. However as the car is old it detects MBR partitioned usb only. So conclusion is - USB should have MBR partition. |
06-13-2021, 02:13 PM | #7 |
Rep 7,484
Thanks for the update…glad you figured out the problem.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
05-15-2023, 01:43 AM | #8 | |
Rep 74
I spent half a day trying and researching this. Now the MP3 transfer works. Need to test to update my map too. How can BMW develop a port that only accepts MBR partitions. Nice and short video on how to change partitions. |
03-14-2024, 06:35 PM | #9 |
Rep 1
I just bought an F10 520D 2011. I would like to know if it is at all possible to update my iDrive software and maps in 2014. I tried several ways, there is no indication that the glove box USB port is detected, it charges my phone though. Entering the VIN in the BMW update site does not produce any result. Bought a code and maps from ebay, but unable to do anything with it.
The digital owner's manual does not say anything about the glove box port. Music does play from the armrest port with no problem. Please let me know if anything is possible. Thank you in advance. |
