2010 2011 BMW 5 Series Forum F10 Dual to quad exhaust set up |
03-29-2023, 12:29 PM | #1 |
Rep 334
Hi everyone, I'm currently running a stock exhaust on my M sport 535ix and was thinking to go quad. I only want to change the tips since I don't mind the stock exhaust and wanted to ask for some advice. Please let me know if you have done this conversion and what was needed for it?
Thank you! |
03-31-2023, 01:27 PM | #2 |
Rep 369
Drives: '09 E90 328i 6MT, '16 F10 535i
I'm sort of interested in this too, except I have the M Performance exhaust. Presumably, you'd require a new diffuser to fit the new tips. My main concern with replacing the diffuser is that I've read with most aftermarket solutions, you lose the comfort access kick-to-open trunk feature. Might not be a deal breaker for you, but for me it is since I use it quite often.
zvery777271.00 whmissi1230.00 |
03-31-2023, 03:54 PM | #3 | |
Rep 334
04-01-2023, 03:15 AM | #4 |
Rep 16
I use to run quad exhaust tips on my stock muffler M Sport 535i before changing to M5 mufflers. You will need M5 diffuser (or bumper cut if your car does not have M Sport body kit) and a set of "h" pipe exhaust tips, you can get these tips from eBay AliExpress etc and a good muffler shop to install the tips.
zvery777271.00 |
04-01-2023, 05:50 AM | #5 | |
Rep 334
Also, do you have the kick to open trunk option? |
04-01-2023, 08:51 AM | #6 |
Rep 16
04-02-2023, 11:03 PM | #7 |
Rep 262
Others have relocated the comfort trunk access this with an adapter. Hope it helps.
https://f10.5post.com/forums/showthr...ensor+diffuser
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
zvery777271.00 CrippledLucifer127.00 |
04-15-2023, 01:45 AM | #8 |
Rep 14,522
like mentioned above you'll need to get some h tips!
zvery777271.00 |
04-25-2023, 06:54 PM | #9 | |
Rep 458
I have an M5 exhaust to install on a 550i modern with the square exhaust. I don’t think the comp fits on that bumper. I want to install this within the month. |
05-01-2023, 06:14 AM | #10 |
Rep 16
Yes, the M5 diffuser only fits the M Sport bumper, which is exactly the same as M5 bumper
05-09-2023, 08:35 PM | #11 | |
Rep 12
05-14-2023, 12:41 AM | #13 |
Rep 16
03-14-2024, 06:39 AM | #14 |
Rep 3
Can someone give me the link for the quads exhaust tips for please there is so many online i dont eant tonorder the wronf one. I have a bmw 535 m package 2016 and just ordered the wuads diffuser
