2010 2011 BMW 5 Series Forum F10 G Plus Intercooler Install DIY |
05-14-2020, 10:28 AM | #89 |
Rep 2,595
Brackets are supposed to come, but if you read a few pages back there's a lot of reports of various sellers forgetting them. If you contact the seller they will send it to you, but it's annoying to have to wait again lol
2015 BMW 535xi
lsturbointeg9167.50 |
05-14-2020, 11:27 AM | #90 |
Rep 14,521
Ah that sux. I was thinking you can contact GPlus directly but I forgot the Gplus is sold by ebay sellers and not GPlus themselves
05-25-2020, 08:15 PM | #91 |
Rep 14,521
Hey fam! finally completed all the FBO by finally ordering my IC! sounds like everyone's happy with theirs so can't wait to get this installed!
05-26-2020, 09:14 AM | #92 |
Rep 668
woot woot!!! You and your car will love it. Especially going into the summer heat.
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
06-04-2020, 04:12 PM | #93 |
Rep 916
Does it seem to hold boost better with the new IC? Also, do you think stock boost will benefit from this?
06-04-2020, 07:41 PM | #94 |
Rep 441
I would not get into the IC having any performance gain expectations. All you'll probably notice is that you don't notice such worse performance on hotter days and/or after back to back pulls. Day to day, you won't notice it's there. (I have Wagner, which is supposedly the same thing.)
2013 535xi M Sport (PWG) // PS2 // Spool fx150 // MHD // xHP // FTP Inlet // FBO: AR HF DP, Wagner IC, BMS Intake, VRSF CP
BurrNinja431.50 |
06-04-2020, 09:24 PM | #95 | |
Rep 916
06-04-2020, 11:31 PM | #96 | |
Rep 2,595
Stock boost will benefit from this. You might feel a ever so slight increase in lag due to the larger volume, but I'd seriously doubt you'd ever notice it.
2015 BMW 535xi
06-05-2020, 03:58 AM | #97 | ||
Rep 916
Instgram @burninja
06-05-2020, 12:14 PM | #98 |
Rep 2,595
Lower IAT actually lowers the amount of boost your turbo needs to push. Cooler air = more dense to begin with, so less boost is needed to achieve the same power levels. The hotter the IAT, the more boost you need to run to compensate for the lower density.
2015 BMW 535xi
06-05-2020, 02:23 PM | #99 | |
Rep 916
Instgram @burninja
06-05-2020, 05:27 PM | #100 | |
Rep 2,595
2015 BMW 535xi
06-05-2020, 07:34 PM | #101 |
Rep 14,521
Debating whether or not I should upgrade the other remaining pipes while I'm doing the GPlus IC? Any benefit to this?
06-05-2020, 09:13 PM | #102 | ||
Rep 916
Instgram @burninja
Unspec1311.50 |
06-05-2020, 09:28 PM | #103 | |
Rep 2,595
Though just as a heads up, these are highway speeds. If you're sitting in stop and go traffic, you're still going to heatsoak after a bit. Just letting you know so you know what to expect
2015 BMW 535xi
BurrNinja431.50 lsturbointeg9167.50 |
06-05-2020, 11:42 PM | #104 | ||
Rep 916
Instgram @burninja
06-05-2020, 11:49 PM | #105 |
Rep 2,595
Absolutely not, agreed. It's a wagner clone, so you know it was at least designed well.
2015 BMW 535xi
BurrNinja431.50 |
06-06-2020, 04:08 AM | #106 |
Rep 14,521
i think this is the left side LIC that can be replaced? which to me would be a pretty good preventative maintenance upgrade since the dp is just below this which would cause the OEM pipe crack over time?
and than here's the boost pipe on the right side that connects to the CP
06-06-2020, 01:23 PM | #107 |
Rep 441
I haven't seen the need to replace those as a preventative measure - seems like oem is reliable enough, unlike a CP.
FWIW: I had a boost leak at the o ring of the boost pipe between the turbo and IC - I had to replace the whole pipe (bc you can't buy only the oring ), and shop said stay oem bc they see more issues with aftermarket replacements than the oem pipe. |
06-06-2020, 01:55 PM | #108 | |
Rep 2,595
2015 BMW 535xi
06-06-2020, 05:00 PM | #109 | |
Rep 199
06-07-2020, 12:53 AM | #110 |
Rep 96
For what it’s worth, I got my P3 gauge in the other day so I had some fun watching my IAT with the G-Plus the last couple days.
Yesterday was in the upper 80s and I ran about 8-10 above ambient at 55-70 mph speeds. WOT pulls at these speeds would see a spike of 15-20 degrees which cooled back off quickly at highway speeds. Driving at 30-40 mph within the city in traffic, I saw IAT in excess of 30 degrees above ambient at times. These are excellent results for a $600 intercooler, let alone a $240 one.
2014 535i xDrive | MHD Stage 2+ | ER Catless DP | ER Charge Pipe | G-Plus Intercooler | Walbro 450 LPFP | Staggered 20” Avant Garde M359 |
