02-12-2020, 02:53 AM | #1 |
Dream crusher
984
Rep 2,421
Made the move and purchased a VTT Crankcase breather.
Read many articles about increasing boost puts more stress on the seals exposing oil leaks, increased blow by and increased pressures making internals work harder. Worst of all our N55's have the notorious whining caused by a blown VC diaphragm. We also have the even more infamous OFHG that leaks like plastic bag punched with holes. The articles go own to mention that performance increases can be anywhere from 1-3% by lowering internal pressure to 0 or atmosphere or in some cases negative vacuum. I can't confirm that but i will say the engine revs noticeably better. The shifts between gears stays in a higher rpm and don't fall as fast. Similar to a down-pipe it carries a heavy gas smell. Maybe not as pungent as a decatted pipe but the gas/oil fumes are prevalent. People state that there's poor hood clearance issues but i am not experiencing that. Fits perfectly on the valve cover and the hood closes without problems. I'll see how this goes as a daily. Might switch back to a cap and use this mod for the track. However, if I ran 20+ psi daily I would keep it in to prevent the negative effects mentioned above. A catch can that has a baffle for aeration could be the ultimate daily combo that covers fumes and provides lowered internal pressures for boosted cars. The quality of the hardware is top notch minus the faded logo on the top of the filter. The filter itself is quality.
IG: @bmwdoubles |
02-12-2020, 04:46 PM | #2 |
Rep 1,445
Drives: F10 S55, E93 M3, E89 N54
NICE! Is there a one way check valve on it or is it wide open?
02-12-2020, 06:50 PM | #3 |
Dream crusher
984
Rep 2,421
There's a check valve that opens at <0.5 psi
So far it's been a heavy gas smell and this morning my garage smelled like a gas can. I had a long crank. Might be unrelated but we'll see. I have no codes. I will say the car does feel peppier. There could be a performance gain*? : My next move that is similar to reliving pressure is manual gearbox and transfer case fluid changes. Tons of good reviews on performing that maintenance item.
IG: @bmwdoubles |
02-12-2020, 08:51 PM | #5 |
Dream crusher
984
Rep 2,421
It's track mod def not a daily. When you're driving is fine if you're out of stop for too long it's very strong. If you have this man and a downpipe you would need an oxygen mask to drive the car LOL. I am enjoying it because I feel like my engine is revving better
IG: @bmwdoubles |
02-12-2020, 08:59 PM | #6 | |
Rep 1,299
Maybe it's one of those mods to switch on days when you want to do spirited driving or going on a highway drive towards city and wanna enjoy the full power. |
02-13-2020, 10:17 AM | #7 | |
Rep 2,595
2015 BMW 535xi
02-13-2020, 10:27 AM | #8 | ||
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
02-13-2020, 10:45 AM | #9 |
Rep 1,445
I have a catless dp and my wife only complains when we are stopped and the windows are down, I personally enjoy the smell, reminds me of what I'm driving. Maybe I'd like it even more with this vent lol.
I would imagine a catch can with a breather on it would stink just the same... For 100 bucks maybe a catch can would be a better way to spend the money and kill possibly two birds with one stone? |
02-13-2020, 10:59 AM | #10 | |
Rep 2,595
Personally I'd never got cat less. The fumes from the high flow cats already make me a little nauseous, so I think if I went catless I'd actually PTFO
2015 BMW 535xi
02-13-2020, 11:22 AM | #11 |
Rep 1,445
WAIT, how is this different than the crank case breather hose that vents to your air intake? In fact that vent, since it's connected to your intake, would actually be SUCKING air out of the crank case.
Please someone smarter than me explain. |
02-13-2020, 12:05 PM | #12 |
Rep 1,299
Good question, I want to know this as well. Maybe it helps release extra pressure that the tiny pipe can't.
02-13-2020, 02:07 PM | #13 |
Rep 5,408
02-13-2020, 02:53 PM | #14 |
Rep 1,299
02-13-2020, 07:18 PM | #15 |
Rep 1,230
i have this with the BMS catch can. Mabey overkill but hey
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
02-13-2020, 07:27 PM | #16 |
Rep 1,445
With a name like $howtime, is there such a thing as overkill? Lol
02-13-2020, 10:53 PM | #18 |
Dream crusher
984
Rep 2,421
Ok turns out it wasn't the VTT breather. I had an actual fuel leak coming from the low pressure side that connects to the hpfp. Surprised my car didn't lite on fire. Hello insurance money lol.
IG: @bmwdoubles |
02-14-2020, 08:25 AM | #19 |
Rep 2,595
...yikes that's spooky. Too early in the year for such drama. This is why I carry an extinguisher in my car lol
2015 BMW 535xi
02-14-2020, 08:28 AM | #20 |
Rep 1,445
Wow, you should fire the mechanic that installed that thing! :-)
02-14-2020, 08:40 AM | #21 |
Dream crusher
984
Rep 2,421
😂 I guess I'm fired. I also wrenched the lp connecting side pretty hard. I suspect that's where it was leaking from. I'll know this weekend. Tearing it all down again is never fun.
IG: @bmwdoubles |
jayster0966209.00 |
02-14-2020, 09:35 AM | #22 |
Dream crusher
984
Rep 2,421
Here's that video of catted vs not
IG: @bmwdoubles |
