2010 2011 BMW 5 Series Forum F10 Climate Control Starts when Starting Car |
06-22-2010, 05:04 PM | #1 |
Rep 1,346
Drives: 2011 E92 335 M-Sport
Do other F10 owners have an issue of the climate control, in this case, fan and A/C, automatically starting when first starting the car?
1. Yes I turned it off before I got out of the car. 2. No the green light on the auto temp controls are not engaged. |
06-22-2010, 05:12 PM | #2 |
Rep 2,248
Mine (older 3-series) runs all the time. That's the way I would want it. If there's an "off" switch, I don't know where it is. Except for the A/C compressor of course.
06-22-2010, 07:41 PM | #4 |
Rep 1,346
06-22-2010, 07:47 PM | #5 | |
Eight Bimmers and counting
35
Rep 761
It's been this way in all of my BMWs since 1996. And my two latest ones (the '07 335i [RIP] and and the '08 M3) heat up INCREDIBLY fast. Like, 30 to 60 seconds after being parked outdoors for almost 18 hours in temperatures as low as 4 degrees Fahrenheit.
2014 F10 M5
Previously... Threes: '08 E90 M3, '07 E92 335i, Fives: '11 F10 550i, '02 E39 M5, '00 E39 540i/6, '97 E39 528i, '92 E34 525i Others: VW, MBz, Peugeot, Toyota, Olds |
06-22-2010, 07:52 PM | #6 | |
Rep 1,346
06-22-2010, 11:19 PM | #7 |
Rep 73
The climate control is designed to be always on with the A/C.
I'm sure you're aware that the heat is applied to keep the desired ambient temperature along with the A/C running. I find that most late model cars do this fairly well... With the exception of a few people like my wife. She hates auto temp and adjust the temperature up and down to the extreme to her taste which annoys me greatly. I personally am not bothered by the high blower speed when the car is trying to adjust the interior temperature. The only time that I turn off the climate control is when I have the windows down and sunroof open so I don't get to do this often... especially here in Santiago where the air quality is among the worst in the world. I'm not sure if this is the same with other/older BMW's but you can turn off the climate control by turning the fan all the way down. I was dumbfounded that there was no "off" switch but I discovered this by playing with it. Is this what you did? I haven't tried to restart the car while the climate control is off so I can't confirm if this is true on my car as well. I'll try tomorrow and let you know. My car is in the basement of our apartment and is a bit of a hassle to go down 13 floors late at night. Last edited by ddd269; 06-22-2010 at 11:28 PM.. |
06-23-2010, 12:37 AM | #8 | |
Rep 1,346
06-23-2010, 12:47 AM | #9 | |
Rep 2,248
06-23-2010, 02:33 AM | #10 |
Rep 683
You should keep it on to keep it in good health. If left off it will start to smell, get dusty, parts will leak or seize-up - big expenses. Leave it on. Set it to Auto and just adjust the temprature to suite you.
2010 E90 335i M-Sport, 2005 E90 325i M-Sport, 2003 E60 520i, 2002 E46 330i Sport II, 2000 E46 325i Sport I, 1999 E46 318i, 1998 E46 323i SE, 1996 E36 323i SE, 1996 E34 518i, 1995 E36 320iA, 1994 E36 316i
06-23-2010, 04:27 AM | #11 |
Rep 15,858
Personally I don't get the reason why anyone would want the Climate Control switched off completely, unless you want all sorts of temperature variations in the car. Can understand why BMW has the system running as the default.
One suggestion... if it is about airflow and the A/C function. Set the system out of the auto mode. Set as you would like it, in manual mode, something like... Switch off the A/C button (if part of the issue) and/or put the fan speed(s) to minimum, but not off. That will log in the memory and start up will always be at that setting. Minimum fan speeds will be maintained and the system will just modify the heat to the preset temperatures, but very gently. HighlandPete |
06-23-2010, 09:49 AM | #12 |
Rep 1,346
06-23-2010, 11:07 AM | #14 |
Rep 1,346
