2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes H&R vs ACS
      01-16-2014, 08:50 PM   #45
ARC550
Drives: M3, X5, 720s, X5, 750xi
I just installed new tires today. Hankook S1 Noble2. 255/40 - all around. The ride is smoother yet I feel more connected to the road. The feel has intensified approximately 15%+ . You can really feel the different. While I had the tires replaced I also painted the brake calipers gloss black. (No decals). I am going to enjoy this setup for about a week or so until I install the M5 sway bar. After that it will most likely be the Dinan springs.
      01-17-2014, 08:53 AM   #46
audiogolf
audiogolf's Avatar
40
Drives: 2023 X7 40i
I am going for my fitment today!
      01-17-2014, 12:24 PM   #47
dan the man
Drives: 2017 M4 CP
Originally Posted by audiogolf View Post
same here, i am going to try with new tires/wheels, got a new set of 20" wheels - TSW panorama and conti dws 255/35/20 and 285/30/20 and M5 front sway bar and M550d rear sway bar. btw: Dinan springs only drop 10-15mm.
The overall diameters for your tires are:
255/35/20 is 27"
285/30/20 is 26.7"
Your xDrive will not be happy with that. Try 245/35/20 (26.8" overall diameter) for the front. If you go for staggered setup you will need to keep the front and rear overall diameters as close as possible.
2017 F82 M4 CP - Black Sapphire Metallic - drive it like you stole it
2014 F10 550xi M Sport - Jet Black - gone
2010 E92 335i Coupe - Black Sapphire Metallic - gone
2004 E46 330xi Sedan - Black Sapphire Metallic - gone
      01-17-2014, 02:36 PM   #48
audiogolf
audiogolf's Avatar
40
Drives: 2023 X7 40i
i know it is off by about 1.1%, but is it not that a difference of under 3% is ok, just wanted slightly wider tires as my front wheel is 20x9. and the ideal size for a 9" rim is 255.
Also, with slight tire pressure changes you can have that height difference between front and back with same tires on all four corners.
      01-21-2014, 05:29 PM   #49
audiogolf
audiogolf's Avatar
40
Drives: 2023 X7 40i
so finally had my wheels and tires fitted, will post pics as soon as this weather clears up.
wheels look really great.
Dan,
went with 245,35,20 instead of 255,35,20 for the front.
could not really test the tires, as whole way back i was only driving at 25 miles per hour. will report soon. Also got the brake calipers painted in red, they give a nice contrast with dark bronze wheels and AW.
      01-24-2014, 01:38 PM   #50
ARC550
Audio- PICS??!!!
      01-25-2014, 09:37 AM   #51
audiogolf
audiogolf's Avatar
40
Drives: 2023 X7 40i
Audio- PICS??!!!
http://f10.5post.com/forums/showthre...0#post15332570
      01-28-2014, 02:31 PM   #52
Super6
Drives: 2012 535xi, 2014 640i
I ordered tires a few days ago. Hankook S1 Noble 2 - High performance all season. 255/40/19. The tires arrived today!! I cant wait to remove the crappy runflats.
I ordered the Sway bar should arrive any day now.
The springs.... I am still going back and fourth if i want to do ACS or H&R.
I am starting to think the H@R is to much of a drop..
Hey how did you like those tires? I have a 535xi and I can't tell if the handling is really that crappy or if its the tires or a combination of both. I have about 900 miles on the tires and I'm taking them off I read the reviews and they aren't recommended for "spirited" driving because of the soft tire walls. I am going with something different, but I am really thinking about changing out my springs while I'm at it, this car just handles like a boat.
      01-28-2014, 03:38 PM   #53
ARC550
Tires are Amazing!!!!!! Highly recommend. I did 255/40 all around. Love it. Would not do bigger nor smaller. they are perfect size. You really feel better planted to the ground. You regain some of that old BMW feel. I love it!
      01-28-2014, 10:47 PM   #54
audiogolf
audiogolf's Avatar
40
Drives: 2023 X7 40i
AR - did u install the m5 sway bar?
      01-28-2014, 11:38 PM   #55
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Audio...who painted your calipers?
Build: '14 M5 - Space Gray / Full Sakhir Orange / Alum Trace / Black 343's / Exec / Driver Assist / LED
Mods: SunTek CXP tint - Vinyl-wrapped door handle chrome - Macht Schnell 12mm spacers - Pedalhaus pedals - iND Cosmetic Package - Polished 90mm exh tips - Coded by v12 - 21" HRE S107's polished lip/black center
      01-29-2014, 06:51 AM   #56
audiogolf
audiogolf's Avatar
40
Drives: 2023 X7 40i
the guys who installed my wheels and tires,
American tire and auto in greenbrook, nj. charged me $52.00.
      01-29-2014, 07:47 AM   #57
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
I'm going to put my wheels on myself, but not sure if I feel like getting involved with painting the calipers................"........
      01-30-2014, 08:15 PM   #58
BimmerMsport
Drives: '13 535i AW M Sport
Just had H&R springs installed on my 535 and call me crazy, but it feels as the ride has gotten smoother. The ride has gotten less bumpy and more mellow in response to road imperfections.
The car exhibits less roll and increased sexy-ness. If you're considering a set of springs for lowering I would highly recommend H&R.
      01-30-2014, 11:17 PM   #59
slownfast
Drives: 2013 528i Xdrive
isn't H&R spring lower than ACS spring? how is the ride?
      01-30-2014, 11:57 PM   #60
BimmerMsport
I feel my stock m sport suspension felt stiffer than the H&R. Can't really opine on the ACS springs since I never tried them.
      01-31-2014, 10:07 AM   #61
HDEddie1
HDEddie1's Avatar
121
Drives: X5 40i, X3M40i, Audi SQ5
Which LA shop did you use?
Where did you buy the ACS springs and which shop did you have install them? Thanks.
Originally Posted by lakerpride05 View Post
ACS all the way! Almost feels like you haven't lowered the car. I had them on my 550 and now have them on my M5. Very compliant. I bought my M5 used that had H&R's and couldn't stand how rough they were. Switched to ACS within a week.
      02-03-2014, 10:44 PM   #62
gragi
Drives: 2011 535i xDr F10 M Sport
H&R all the way! Go H&R it's not too much drop, not at all. Just perfect. Anyway I have them and am very satisfied how the car looks. Good luck!
1996 E36 328i Touring
2000 E46 328Ci
2004 E46 M3 Dinan Exhaust
2011 535xDrive F10 AFE CATBACK, AFE SCORCHER, AFE Performance Air Filter, H&R, AR Down Pipe, ER Charge Pipe.
