2010 2011 BMW 5 Series Forum F10 Radiator fan keeps running high and low nonstop |
10-09-2021, 09:57 PM | #1 |
Rep 24
what's up guys just bought a 2013 BMW 535xi like 2 months ago. it only has like 38k miles on it.
i noticed that when i start the car up and drive about a 1/4 mile down the road the radiator fan will run high speed for like 5 seconds and then wine down and run regular for a few seconds, then wined back up to high speed, then low.. just a constant pattern in speed changes. it never stops doing this even when i come to an idle or put it in park, it just keeps doing the high and low pattern non stop. I have no check engine light at all. now i also noticed that when i start the car the fan doesn't kick on high speed at all, which actually causes the car engine to start running hot eventually.. the gauge gets up to about half way, which is like 250.. but as soon as i drive and get down the road a bit like i mentioned it will kick on and start doing what i mentioned. the car temp will go back down to "normal"but the fan just keeps doing the pattern i mentioned. again there is no check engine light. my coolant is topped off and good any ideas? |
10-09-2021, 11:15 PM | #2 |
Rep 697
Drives: 2013 535xi
Water pump is failing. Same thing happened to mine with exactly the same symptoms.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
Brunner221.00 |
10-09-2021, 11:23 PM | #3 | |
Rep 24
i thought it would just be a bad fan relay or something sheesh |
10-10-2021, 07:32 AM | #4 |
Rep 63
Drives: 2012 BMW 535xi
I had the same symptoms and it was the water pump for me. At the time I had 59k miles. I did have the water pump code though when I scanned the car.
10-10-2021, 09:28 AM | #5 | |
Rep 24
did your fan do it when the engine was cold also? my engine can be completely cold and i'll get about 100ft down the rd and the fan will start doing it |
10-10-2021, 09:32 AM | #6 | |
Rep 697
Drives: 2013 535xi
And yes, mine did it when cold. The fan would start racing as I was leaving the driveway.
10-10-2021, 01:16 PM | #7 | ||
Rep 63
10-10-2021, 01:32 PM | #8 | |||
Rep 24
but i guess it's good it happened now while i'm still under the 90 day purchase warranty so i can get it replaced for free. hopefully they don't try any bull shit with me |
10-10-2021, 01:38 PM | #9 | ||
Rep 24
10-10-2021, 02:47 PM | #10 | |||
Rep 63
10-12-2021, 06:31 PM | #11 | |||
Rep 24
10-13-2021, 06:38 PM | #12 |
Rep 63
Im not sure if any scanner will work. Did you end up using the one at autozone to check?
10-16-2021, 10:47 AM | #13 |
Rep 24
10-16-2021, 02:15 PM | #15 |
Rep 1,363
Regular scanners won't show the codes. Those scanners can only show codes if you get a check engine light. You will need BMW diagnostic tools to show codes. Sometime it won't even throw a code. Like mentioned above, those are the recommended tools to diagnose your car.
If you are replacing the water pump, replace the thermostat as well. It's next to each other. Save you the hassle in the future. |
10-16-2021, 02:19 PM | #16 |
Rep 24
ok bet, i just bought the OBDlink cx for bimmercode. we'll see what happens.. i have another 6 days til my service appointment so hoping nothing goes wrong til then other then what's happening with the fan
10-16-2021, 02:21 PM | #17 |
Rep 24
i did the BMW water pump test that is shown everywhere on youtube and it seems to be working just fine... it's so weird the fan is doing this
10-21-2021, 02:55 PM | #18 |
Rep 333
Drives: F10 535i xDrive, F25 xDrive35i
+1 on the water pump. Mine had the same symptoms and it happened at 55,000 miles.
