2010 2011 BMW 5 Series Forum F10 How is your ride with 20" wheels? |
09-14-2015, 03:51 PM | #1 |
Rep 554
So I've put 20 inchers on my wife's F10 (base model) and it rides very rough. Just wondering if this is common with all 20" setups for F10's or is it because the car is the base model '13. The suspension feels like crap. I mean it bounces around every bump on the road. A week ago we got a 2015 528 M-sport as a loaner and it rode super smooth (granted it had 18" M-sport wheels and is a brand new car). Also, is there anything else I can do to have a better ride besides swapping the wheels back to stock.
09-14-2015, 06:28 PM | #3 |
Rep 554
That's exactly what I thought initially so I changed out el cheapo tires for Pirelli P-0's and it's still very rough. I'm just curious to know if this is the norm or is it just the suspension of our car being that it was a CPO base model.
09-14-2015, 07:00 PM | #4 |
Rep 1,254
what size are you running 245-35-20 front and 285-30-20 rear and what pressure?
Keep in mind ride wont be the same as stock you will get used to it. I am not expert but I had on all my cars aftermarket wheels from 18'' to 24'' its always different good luck |
09-14-2015, 07:01 PM | #5 |
Rep 2,196
I am running OEM 20's with Hankook Evo2 tires and AC Schnitzer springs and my car doesn't drive rough or bounce around at all. I have a 2011 M Sport which came with DHP and all the suspension bells and whistles before they dropped them from being standard with the M Sport package. Actually one of the reasons I went with a 2011 vs a 2012.
Bake
09-15-2015, 12:05 AM | #9 |
Rep 5,140
My F11 with 20" Michelin PSS runs much much better than my previous F31 with 18" Bridgestone run-flats.
It's not only the diameter or sidewall that influence the ride quality, but a number of other factors like suspension type and settings, tire brand, type of tire etc. |
09-15-2015, 12:48 AM | #10 | |
I am groot
25
Rep 149
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order |
09-15-2015, 01:21 AM | #11 | |
Rep 554
09-15-2015, 01:54 AM | #12 |
I am groot
25
Rep 149
I didn't like the 245/35 tire size, it's too narro and doesn't have much to work with to absorbe the roads imperfections. I would try a 255/40r20 in the front, it's a little taller and wider and will put more rubber between you and the road. You could also run a little less air pressure to soften up the ride with a larger tire. My stock front tires were 245's upfront and they we're jarring.
2011 550i M SPORT
09-15-2015, 03:16 AM | #13 | |
Rep 5,140
255/40-20 is almost 5% taller than OEM size and might rub the steering knuckle up front depending on wheel offset. 245/40-20 (3.5% taller) or 255/35-20 (1% taller) will fit though. |
09-15-2015, 11:20 AM | #14 |
I am groot
25
Rep 149
A 255/40 will fit all day long and won't rub on anything. It's only 1.28" taller than what he's running now. Some people who have the m sport 19's run a 245/45 and its .93 taller than what he's running now and they don't rub. The difference between 1.28 and .93 is like a 1/4" it will make a difference in the ride and won't rub. He could also put on coilovers if it's not the tires.
2011 550i M SPORT
09-15-2015, 11:54 AM | #15 |
Rep 5,140
No need to be cocky, but since I have fitted 255/40-20 up front I know they will rub the steering knuckle depending on wheel offset.
Less than 1/10" clearance with the car on the lift and rubs with the weight on the wheels. |
09-15-2015, 12:15 PM | #16 |
I am groot
25
Rep 149
Sorry I didn't realize that everyone has the same wheel offsets as you do.
2011 550i M SPORT
09-15-2015, 02:11 PM | #17 |
Rep 5,140
OP didn't provide info about wheel offset.
But I checked available 8.5x20" TSW wheels for BMW, all models are ET35 except one that's ET30. The picture above is with ET32. |
09-15-2015, 02:33 PM | #18 |
Rep 554
Just to answer your question, front and rear are ET35. Thanks for all the recommendations. I'll go for larger OD tires before I have to swap back the stocks, which is what my wife wants right now because she's really frustrated.
09-15-2015, 02:39 PM | #19 |
Rep 5,140
Thanks for offset info.
The 255/40-20 tire tread rubs against the steering knuckle because it's too tall, not too wide. This means that the offset will not be that important in this case as long as it's between 20-35. To completely clear a 255/40-20 tire from the steering knuckle the offset needs to be around 10-15. But with that low offset a 255/40-20 tire will rub the fender liner during both compression and steering so that's nor an option for a rub free setup. I dont like the idea of giving advice to a forum member without own experience if the tire will fit without rubbing or not. Therefore I shared my knowledge regarding 255/40-20 up front on F10/F11. |
09-15-2015, 02:44 PM | #20 |
I am groot
25
Rep 149
He is right and I'm am wrong, I just looked at my car to compare to his pic and a taller tire like the 255/40 is a tight fit. I would go 255/35 it's about a half inch shorter so it won't rub, but i would still consider going wider as it will make a larger contact patch and absorbe the road better. You did mention your car is a base model so a coil over upgrade will prolly be the best option.
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order Last edited by Autobuffoonery; 09-15-2015 at 03:15 PM.. |
09-16-2015, 06:51 AM | #21 |
Rep 603
How did your car ride before the wheel swap compared to the new 528 you drove? How many miles do you have on the car?
- 2022 X3M Comp
- 2021 X5 xDrive 40i - 2018 F80 M3 (sold) |
09-16-2015, 12:53 PM | #22 |
Rep 554
As I can remember, the car drove fine (stiff suspension but not rough) but it definitely didn't feel like a new 528. We bought it at 36K miles so that's understandable, plus technology has changed somewhat. It's sort of like comparing apples to oranges with a new car. I was hoping to get some insight from a '12-'13 base model owner that has upgraded to 20" wheels. Although coil-overs would be a nice upgrade, since it's my wife's daily commuter, I'm not sure I want to spend a few thousand on it. We bought it as a beater for her but I then had the urge to make it look nice with the wheels. It's becoming more of a headache than its worth.
