2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 245/45/19 and 275/40/19 on 11 msport?
      06-16-2016, 04:24 PM   #1
03redtypes
Drives: 2011 535i Msport
Will these work with no rubbing issues? Running the OEM 351m staggered wheels. Want a little taller sidewall. Only thing I found was a thread for a 650xi I believe it was. Just wanna make sure before I order or someone with pics even. I know the overal height will be an inch taller. But as far as rubbing up front. I believe the ones in the rear will be fine. Thanks in advance.
      06-17-2016, 03:26 AM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
No issues with those sizes!
Fills the wheel wells very well since the diameters are 3.5% taller than OEM sizes.
      06-17-2016, 07:00 AM   #3
03redtypes
Perfect, I knew it would fill the wells a little better. So looks like I'll go this way. Any other opinions are welcome! As well if any pictures.
      06-17-2016, 09:55 AM   #4
PJinCA
USAF Pararescue Veteran
Drives: F10 535
The only effect will be that if the overall diameter is 3.5% bigger (as .BMW. stated) the speedometer may be slightly off. That is the reason people try to stay within 3%, anything over will make your speedo off. The difference would be minimal, but it will be there. If you're good with that, then those tires will work fine.
It is more of an effect on larger tires like 20", where those sizes tend to be intended for light trucks (pickups and SUVs) rather than cars.
      06-17-2016, 10:42 AM   #5
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
I use 245/50-18 (same diameter as 245/45-19) as winter setup. The speedo show correct speed, checked with GPS.
All BMW's show a few percent higher speed than actual with OEM tires sizes.
      06-17-2016, 11:02 AM   #6
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Here is my F11 with 255/40-20 (almost 5% taller than OEM size) for reference.
      06-17-2016, 06:57 PM   #7
bsavvy
Drives: 535i xDrive M Sport
Meaty.
