2010 2011 BMW 5 Series Forum F10 Tire Pressure for Non FunFlat tires??? |
07-29-2013, 02:05 PM | #1 |
Rep 471
I recently got Non RunFlats installed on my 2013 535i M-sport. Normally the Runflats call for 35 psi front and 38 Psi rear.
Should the tire pressure be different now that I am running non Runflats on my car? Thanks |
07-29-2013, 09:37 PM | #2 |
Rep 937
No, start with 35 and 38 and adjust a bit from there. You might also use the load rating of your new tires as an adjustment factor. If the load ratings of the new tires are higher than the OEM tires, you can generally run a bit lower pressure. The opposite is also true. In any case, you should be within a couple of pounds of 35/38.
