2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 Owners, does your car hesitate or jerk at 0-10 mph??
      08-10-2010, 02:42 PM   #23
Simmo24
Simmo24's Avatar
Drives: BMW 640i Convertible
530D, smooth as silk, no lurching or jerking. It sounds like it's mainly petrol models. Any more diesel owners out there ?
      08-10-2010, 03:21 PM   #24
LLepard
Drives: 2010 750 xi
Originally Posted by tadtaggert View Post
More top end power, slower off the mark. The six has more low end torque.
Also, may be a function of the extra weight in the 7 Series xi. It is a BIG car. 550i may be different.
      08-10-2010, 03:22 PM   #25
ilsb
Drives: 2011 535i
Pramit, would like very much to get a copy of that repair sheet. My dealer is uncertain of fix. I have to "splain" to them what has to be done otherwise I get car back with "could not duplicate customer's problem"...like I have nothing better to do than make up shit and try to get them to solve it.
      08-10-2010, 03:43 PM   #26
Whteverjklasdf
Drives: .
it jerks a little when the engine's cold.
      08-10-2010, 04:01 PM   #27
tadtaggert
Drives: 550i F10
/boggle
      08-10-2010, 04:08 PM   #28
LUDWIG
Drives: 2011 535
F10 - 535, May 2010 build: Hesitates when starting out cold.
      08-10-2010, 09:50 PM   #29
shukrim07
Drives: BMW 328xi
Same problem here; 528i from Canada. I'm taking her in this week to get it looked at, will keep you guys posted.
      08-10-2010, 10:22 PM   #30
MarkyMarc
Drives: 2011 BMW 535i
Ludwig and Sealobo,
So are you saying your issue occurs ONLY when it's cold and then it's smooth as silk with every low speed creeping departure thereafter? Because mine is eradic even when the car is warm....It can't find the right response.
      08-11-2010, 03:12 AM   #31
gorban
Sweden
11
Drives: F11 520xdAT, E87 120dM
I read about this in a Swedish car magazine. They test drove the 523i and said that the gearbox goes into lock-up even at low gears and you get the kind of engine braking that you have with a manual gearbox. The writer thought it was a normal feature of the 8sp gearbox, but it could also be a malfunction I guess.
      08-11-2010, 04:03 AM   #32
akhter
akhter's Avatar
420
Drives: 911 992 C2S
that should only happen in sports mode. i am saying that because my e90 in DS mode used to powerbrake.
      08-11-2010, 06:24 AM   #33
Dr. Mohammed
Drives: BMW 528i 2010 (f10)
Hi
I have the same issue too, mine is a 528i. I told the dealer about it and he said it was normal!! Since there is a fix, I guess it's time to complain.
      08-11-2010, 07:34 AM   #34
Lukeswarm
Always Warm
Lukeswarm's Avatar
Drives: BMW 318i M-Sport
Yeah, but I am going back to the 5 anyway. The 7 is great, but too big for my taste. I also think the straight six is a much better engine than the V8. The V8 is like a freight train once you get it going, but it takes longer to get going. The torquey straight six is much better IMHO. The 6 really is the perfect engine.
LL
You have a 2010 750 and a year later going for a 5 ... Do you have a money tree at the bottom of your garden!
      08-11-2010, 03:16 PM   #35
pramit
Drives: 2011 535i
Lightbulb Here's the repair sheet
As promised... here's my repair sheet. If your car is doing the lurching/jerking between 0 and 10mph when you start slowly from a full stop (cold, or warm) take it in to your dealer to get it fixed. You should NOT have that problem. There IS a fix and you can take in my repair sheet to show them what they need to do to fix it.
Best of luck!
Pramit
2011 535i Dark Graphite+Black Dakota | ZCV | ZPP | ZP2 | ZSP | Sport Auto
      08-11-2010, 03:52 PM   #36
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
I drove a 530d today and, as promised in my earlier reply, I made a point of trying to repeat your problem.
Not a hint of hesitation, even at the slowest speeds possible from standstill. Just silky smooth in all conditions and I'm convinced - these BMW big diesels just get better and better.
      08-11-2010, 04:09 PM   #37
tk005x
Drives: F10 535i
Same thing here. Haven't not really driven around on sport mode. Also the car shakes a bit when I first start it, anyone else getting that as well? Otherwise I do get the jerking very rarely when the car is warm but otherwise it's been very smooth.
      08-11-2010, 04:33 PM   #38
ibimmer954
Drives: '23 i4 M50, '15 M3, '18 911
Yes, when my engine is cold after first starting it, the whole car will shake while the engine idles at a stoplight. It does this only for the first couple of minutes after it runs. I look down at the tach and it starts shaking at about 600 - 650 rpm. Maybe the idle is set too low when the car is cold.
And this isn't an auto tranny issue, because I have a 6MT. This issue occurs with the clutch pedal out with the shifter in neutral. Or with the car in first gear and the clutch pedal in.
      08-11-2010, 04:36 PM   #39
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
Same thing here. Also the car shakes a bit when I first start it, anyone else getting that as well?
Yep. Not all the time. But if I start the car and sit there trying to mess with the seat or radio, the car shakes a bit. Not major but it's noticeable.
      08-11-2010, 09:26 PM   #40
MarkyMarc
Pramit!
You are righteous and mighty!!!! Thank you for posting that for us. What you describe is textbook what I'm experiencing right now, and hopefully my hour in traffic tonight, jerking and lurching forward will be one of my last!! As time goes on, I hope others who have this issue post their appreciation of you for sharing this info with us!!
You Rock!
      08-12-2010, 12:17 AM   #41
pramit
Drives: 2011 535i
Be nice to the guys at your shop. And be prepared for a wait of a few days while the part gets there. I dropped my car off on a Monday and got it back on a Friday.
Best of luck! Hiccups are no fun. When I got her back, fixed, I almost had an instinctive tensing when I started driving in anticipation of the jerk.
P
      08-12-2010, 11:30 AM   #42
ilsb
Drives: 2011 535i
Pramit,
Thanks much for the info. This is exactly what I am experiencing. You saved me many trips to dealer where they "cannot duplicate customer's problem". Thanks again.
      08-12-2010, 09:57 PM   #43
alex_c
alex_c's Avatar
15
Drives: 2011 f10 535i
Got my 535i today, July 6 build. Drove 200 miles and about 3 hours, with and without traffic. Smooth as silk. Very linear and predictable in Normal and Sports mode. No issues to report.
      08-13-2010, 11:48 PM   #44
lindros2
Drives: 535i M-S
Mid-July build. I've got the jerkiness.
Tags
hesitation, lurching, no response, pause, transmissio
