2010 2011 BMW 5 Series Forum F10 Bavsound Revenant vs. Powered sub in the trunk |
01-02-2021, 02:46 PM | #67 | |
Rep 14,521
also what's great about tuning the parameters yourself is what sounds good to me may not sound good to you. so you can tweak your system to your liking. i'm in the middle of finally getting my home theater together again but every speaker has it's own dedicated signal/frequency. all low level signals will be handled by my 2 12" Klipsche. the tall tower speakers you see think of them as your door speakers and underseats that will handle frequencies 125hz and above. i guarantee that Revenant amp is tuned for a factory system or even a Bavsound. but not with an external subwoofer. you want the capabilities of tuning if that's the case. that's a lot of money for that amp and it would suck to find out in the end you need to make adjustments because the RF sub is interfering with the underseat subs giving you that muddy sound. i know this because that's what i got when i just plugged the MatchUp the first time. good luck!
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 01-02-2021 at 02:54 PM.. |
burro_blasta131.50 Jamesmick131.00 |
01-02-2021, 03:49 PM | #68 | ||
Rep 441
I'm going to push them a bit more on this and will come back. So yea, the Revenant comes with two tunes - one for stock speakers, and one for their Stage 1 speakers. The more I stewed on the idea of a pre-tuned amp the more I liked the idea bc I'm a bit intimidated by the detailed tuning process...to your point the tech side is not rocket science but I just don't trust my ear enough and tend to convince myself of different things at different times, I'm still tweaking my RF sub settings!! God knows what torture I'd do to myself with that many more speakers... Love that home theater bright side of a homebound 2020 is you def got your money's worth!!!
2013 535xi M Sport (PWG) // PS2 // Spool fx150 // MHD // xHP // FTP Inlet // FBO: AR HF DP, Wagner IC, BMS Intake, VRSF CP
01-02-2021, 06:14 PM | #69 | |
Rep 14,521
01-04-2021, 09:37 PM | #70 |
Rep 441
Aight so Bavsound essentially said that yea, of course their tunes don't account for an extra sub but that doesn't make the tune "wrong" by any means and it's still going to be kick ass.
With that mudiness you heard, wasn't that before you had your RF sub hooked up and before the amp was tuned? If so, I'm still not sure that it'd be so noticeable at this point if, to test/replicate, you simply lowered your underseat high pass filter to overlap with your RF now that everything is set up. But to your points, I've now seen other posts like the attached screenshot but I've had my RF going with everything else stock for months and I haven't noticed muddiness or the "delay" issue he mentions. It's definitely bc of my non-audiophile untrained ear but point is I'm wondering if this is really a big issue or if we're in splitting hairs territory...so it comes down to two options for me: 1) figure we're just splitting hairs, use Revenant Pro with professional tune, eventually paired with bavsound stage 1 speakers, which the other tune is specifically made for and hopefully is excellent 2) use match UP 7bmw (also with stage 1) and do the tune myself, including the underseat sub filter adjustment of course I'm feeling like the benefit of the professional tune in #1 - especially with stage 1 added - will be so much better than any tuning I'd do in #2 that the benefits will outweigh the sub-optimal underseat sub situation. But that's on the assumption that the muddiness isn't actually that noticeable, which I (and Bavsound) may very well be very wrong about. Curious if you think I'd really be screwing myself or if it's more of a shrug at this point. Appreciate the back and forth on this!
01-05-2021, 12:39 AM | #71 | |
Rep 500
1. Overlapping of certain low frequency causing either boost or cancellation depends on your sub timing. 2. Didn't offload your underseat sub low frequency to subwoofer. You are asking the underseat sub to play frequency that it can't produce thus higher distortion. A good integration would have a smooth transition from underseat sub to subwoofer. Timing is very important as if not set properly will cause cancellation at crossover frequency. This is common problem in Home Theater subwoofer tuning especially with multiple subwoofer. You need a calibrated mic with REW running on Windows to capture the frequency response of your sound system to do proper tuning. If you do not have the tools or skill, get someone who have experience in audio tuning would be better. No guessing involved. |
01-05-2021, 07:57 AM | #72 | |
Rep 441
And on #1, sort of same question I had to lsturbointeg...I'm understanding the concept but is this something that's really very noticeable to the average listener?
01-05-2021, 05:32 PM | #73 | |
Rep 500
As for timing of the sub, yes it's very important. If the delay cause cancellation at the crossover frequency you will feel lack of mid bass punch from your overall system. If it boost too much at the crossover frequency your system will be very boomy and overwhelm your mid and high. |
burro_blasta131.50 |
01-05-2021, 07:46 PM | #74 | ||
Rep 441
01-05-2021, 07:49 PM | #75 | |
Rep 500
01-05-2021, 09:23 PM | #76 | ||
Rep 441
01-05-2021, 11:49 PM | #77 |
Rep 500
https://www.linkwitzlab.com/frontiers_5.htm
I think this graph will explain the delay relationship between the speakers and subwoofer. When the speaker and sub is out of time alignment, the freq that arrive near the crossover will be different for both speakers. It can cause cancellation thus lower db near that freq. The effect would be less bass at that region (normally consider mid-bass punch at 80hz). |
01-06-2021, 11:15 AM | #78 | |
Rep 441
Given that, I'm now thinking that bimmertech is a better route for me...get their plug n play door components and their tuned amp. Amp is weaker than the bavsound option but overall I'll save a few hundred bucks - bimmertech amp is a little cheaper and I can buy their door speakers a la cart not the entire bavsound stage 1 set - and then I can adjust the underseat cut off myself and take it somewhere to get tuned if the bass is a real issue. With bavsound it seems like the amp and maybe speakers are higher quality but it's more expensive and there's the risk it'd be wrong with the sub and I'd never be able to adjust
01-06-2021, 05:57 PM | #79 | |
Rep 500
lsturbointeg9163.00 |
01-06-2021, 09:22 PM | #80 | ||
Rep 441
01-06-2021, 11:25 PM | #81 | |
Rep 14,521
01-07-2021, 12:15 AM | #82 | ||
Rep 441
01-07-2021, 04:36 AM | #83 |
Rep 14,521
okay cool! that's what you want. the ability to be able to tune and set parameters for your liking. you'll be glad you did
01-11-2021, 03:20 PM | #84 | |
Rep 441
Looks like to start, I will load the AF limousine tune, raise the underseat woofer highpass filter from 30 to around 80, lower the sub output lowpass from 100 to around 80, and input the measurements from my speakers...that a good start? (Eventually I'll get the microphone and do the pink noise time alignment analysis.) Pierreye, do you have a tune file for an f10 with stock speakers + trunk subwoofer? I saw in another thread you mentioned you're RHD so I'd have to switch right/left but it'd still be helpful to see the tune if you have one.
01-11-2021, 06:07 PM | #85 | |
Rep 500
02-09-2021, 01:52 PM | #86 |
Rep 441
pierreye and lsturbointeg know this, but for posterity's sake, just have to note that the Match UP 7BMW amp is excellent.
I made the basic tweaks I laid out above and it's already great. Even though I have the RF sub in the trunk, I'm really grateful for the higher wattage it sends to the underseat subs because it really fills out the sound in a way I didn't expect. In general the sound is much more separated, the deep bass hits well, the vocals and highs are clear even in the face of heavy bass. I haven't used the microphone time alignment or changed the EQ away from the default Limo settings but it's already plenty good enough to let it sit for awhile. If anyone finds this because they're trying to decide on amps, it's easy to see I was intimidated by the DIY tuning but those few steps were easy and sound great and in the long run it's fun to know I can mess around more.
pierreye212.00 lsturbointeg9163.00 |
02-13-2021, 07:41 AM | #87 | |
Rep 14,521
have you tried listening to just the system without the RF sub? sounds pretty weak still right? maybe i'm a bass head but for the bass head guys you still need a sub in the rear.
02-14-2021, 11:51 AM | #88 |
Apprentice
86
Rep 491
I'd be curious to learn how the Match Up 7 upgrade for the HiFi system compares to the factory B&O system and amp. Anyone compared the two side by side (relatively speaking)?
