2010 2011 BMW 5 Series Forum F10 Black Kidneys + Night Vision. Yep, I did it. |
03-21-2012, 01:41 PM | #1 |
Rep 1,377
As most are aware BMW does not offer the black kidney grille accessory for vehicles with Night Vision. Why? I have no idea.
I really wanted the black grilles, so I knew I had to make my own. First, I ordered a replacement set of the standard grilles with NV housing. The camera mount is gigantic. I dropped them off with my friend at a local body shop. He made easy work of the chrome on the slats, sanding them, and then painting them matte black. The chrome bezels, however, presented a challenge. When I realized they were detachable a lightbulb went off in my head. I then ordered a set of black grilles through Tischer thinking I could use the bezels from those. In typical BMW fashion, I could not. The clips lined up differently. At this point I encouraged my friend to sand the chrome. Several sheets of 220 later the chrome was gone, down to the plastic. Painted glossy black with very good adhesion. The paint is an almost exact match to the shadowline trim on the car. I couldn't be happier. As for installation, the NV camera housing is secured to the inside of the bumper using a bolt that is accessible from an access hole overhead. Once removed, the grille can be released. You need to disconnect the washer hose assembly and the harness. What BMW did that made things easier was securing the housing to the grille with several clips and 3 torx bolts. Unscrew and remove housing from old grille, insert in new, reinstall, done. First pictures. It looks nearly identical to OEM. I remembered to clean the blood from my hands off my bumper before taking these.
Current: 2015 X5 M - Donington Grey/Mugello Red - DINANTRONICS Stage 2 + Free Flow Exhaust - Bimmerpost Featured!
Past: Bimmerpost Featured 2014 X5 xDrive50i · 2014 Jeep SRT · 2013 Tesla Model S P85+ · Bimmerpost Featured 2013 F10 M5 · 2012 550 xDrive · 2011 M3 ZCP |
03-21-2012, 01:51 PM | #2 |
1767
Rep 7,652
Looks good. I wonder if BMW will consider a Performance NV front grill. Regardless, nice job taking things into your own hands.
03-21-2012, 01:56 PM | #3 |
Rep 174
Looks great! Good work...
Do you have pics of your interior with the piano black trim? Did your car come from the factory with piano black interior trim? Or did you order it and install? I like my anthracite dark trim very much but I like the piano gloss black even better, especially since my car has a gloss black accent theme. |
03-21-2012, 02:13 PM | #4 |
Rep 29,202
Great job, couldn't look better.
03-21-2012, 03:09 PM | #5 |
Rep 1,377
I have a couple pics (mostly dark) that I can post. The car was ordered with it but the wrong trim was installed. BMW dispatched the pieces shortly thereafter.
Unfortunately it has turned out to be a complete waste of money. The trim swirls and scratches far too easily. It looks horrendous in direct sunlight, especially the passenger side dash and the center console. I'm pulling it out and going back to Hexagon. I'm going to have my detailer try to polish it and then I will Opticoat it. If I'm satisfied with the results I may reinstall it. Or, I'll just wait until later in the year when BMW releases their M Performance CF trim kit for the interior. The option cost $1,100 and was special order. Individual pieces total near $3,000. I should note that there's a cheaper option - color code 4AT - that is basically "gloss black" plastic trim, standard in Europe. It's far, far cheaper than the piano black and I've heard it holds up significantly better.
Past: Bimmerpost Featured 2014 X5 xDrive50i · 2014 Jeep SRT · 2013 Tesla Model S P85+ · Bimmerpost Featured 2013 F10 M5 · 2012 550 xDrive · 2011 M3 ZCP Last edited by wdimagineer; 03-21-2012 at 03:42 PM.. |
03-21-2012, 05:16 PM | #6 |
Rep 17,493
looks really good!
was the same black used on ur grills n interior trim? would u happen 2 kno wut the color is called or wut the color code is?
#datbimmerdoe #thatbimmertho
FOLLOW @datbimmerdoe on INSTAGRAM |
03-22-2012, 12:29 AM | #8 | |
Rep 1,377
Paint on the grilles is just gloss black. I asked my body shop guy to match the Shadowline on the windows and he came incredibly close. Yup. Regret ordering without. Expensive retrofit. Parts for the radio and climate knobs are inbound. Should have them by this weekend. Also waiting on a new shift knob insert with the M logo from the M550dx.
03-22-2012, 09:45 PM | #10 |
Rep 174
Very nice...that's too bad about the swirls/scratches on the piano black trim...thanks for the info...
Do you have a photo of that ///M shifter insert you mentioned? How does that remove/install...is it just the insert? Thanks again, good work, you are into the details like me. |
06-12-2012, 01:16 PM | #12 |
Rep 30
Drives: 2012 535i M Sport
The Clif Crunch Chocolate Chip Granola Bars are my favorite.
06-12-2012, 03:47 PM | #13 |
Rep 5,095
how do you find night vision. It was one option I didn't go for. Had to draw the line somewhere and as most of my driving is on lit roads figured it was not worth the extra.
Does it actually work (well) or would you class it as a gadget? looks nice by the way! |
06-13-2012, 01:33 PM | #15 |
I have to return some video tapes
362
Rep 4,712
sick!
i wanna see the night vision in actipon
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
02-21-2014, 03:19 PM | #17 |
Rep 825
Economically, no. You not only have the lens/harness in the grill, but also the iDrive software and the button on the light cluster.
Down for Maintenance
02-21-2014, 05:10 PM | #18 |
Rep 815
Drives: G05 X5,G20 M340,Infiniti Q50RS
Car is too nice to have the plates like that..put a nice cover over it..
2020 G05 MSport 40i--Phytonic Blue Metallic/Vernasca Coffee Leather/Multi Contour SeatsTrim/Executive Package/MSport Brakes/Icon Adaptive Led HeadlightsW/Laserlight/Harman Kardon/Heated Front Seats Armrests & Steering
02-21-2014, 11:58 PM | #19 |
Rep 947
Ossam job on the grille. I hear ya on the piano black trim - looks a million bucks when new but those swirl marks are inevitable and unfortunately can start to age the interior. BMW's Performance CF trim is sensational and can't say a bad word about it. Love your attention to detail WDI
Current Mistress: 2014 F10 535D M Sport - Alpine White
Retired but not forgotten: 2011 F10 535i - Titan Silver; E53 X5 4.4L Sport - Space Grey; E46 M3 Individual Convertible - Phoenix Yellow; E39 528 - Glacier Green; E36 328 Convertible - Montreal Blue |
07-05-2021, 12:38 PM | #20 | |
Rep 7
