04-06-2017, 12:17 AM | #1 |
Rep 4
343m on a 528i?
I've come across a set of 343M wheels off of a 2014 M5. Will these fit on my 2012 528i RWD? I'm a newb with BMW's and want to be sure of fitment before I pull the trigger. For reference, here's what he sent me in regards to the size:
Front Rims - 9JX20 ET:34 , BMW part # - 36112283999 Rear Rims - 10JX20 ET:34, BMW part # - 36112283401 I'm willing to use spacers, if necessary, for these to work. TIA for the input! FWIW - I did search first |
04-06-2017, 10:12 AM | #2 |
Rep 878
They'll fit, just need a 3mm spacer up front to clear the brake calipers. Loads of pictures on here, not sure how a search didnt yield results.
-WJV
04-06-2017, 12:57 PM | #3 |
Rep 965
I don't think you need spacers unless you have a 550i. I run them on my 535i perfectly.
Quicksilv3r233.50 |
04-06-2017, 03:00 PM | #4 |
Rep 71
If you have msport suspension or lowered you will need 275 width tyres on the rear.or.you will get tyre rub on the arch. I have a set of these currently with 285 rears, haven't got around to fitting the 275's.
04-06-2017, 03:52 PM | #6 |
Rep 2,196
No spacers needed on a 528, they will bolt right up. If you are lowered, 285 rears will work fine as you will get a bit of negative camber. I have a set of these wheels and running 285 rears, and do not have any rubbing. I am on ACS springs and stock M Sport dampers. My car is a 535i.
Bake
Quicksilv3r233.50 |
04-07-2017, 12:25 AM | #8 | |
Rep 4
04-07-2017, 03:05 AM | #9 | ||
Rep 71
If you don't have tires then just make sure you get 275 width on the rear and 255 or 245 for the front, this way you will get no rubbing, there are plenty of topics on the subject if you do a google search. |
