2010 2011 BMW 5 Series Forum F10 F10 (2014) 535i xdrive tire pressure |
03-12-2017, 08:05 PM | #1 |
Rep 76
hi all,
I found out today that one of my tire valve stem caps was stolen.. when I get home, I checked the tire pressure , I realized all 4 tires are low. I was about to refill the tire, but on the user guide. it says "The displays of inflation devices may under-read by up to 1.45 psi/0.1 bar" I was just wondering should I refill the tire to 35psi(front) 39psi(rear) minus 1.45 PSI? Thanks!! also , what does OEM tire air valve stem cap looks like? Mine has N2 written on the top, black cap. plastic.
I am new here. Thank you for your help!!!
03-12-2017, 10:39 PM | #2 |
Rep 14,522
first, what PSI are you currently reading?
03-13-2017, 07:44 AM | #3 |
Rep 76
32.4 32.5 (front)
33.1 33.4 (rear)
03-13-2017, 02:03 PM | #4 |
Rep 237
Your tires are likely low due to the cold temperatures today.
Fill the tires to the manual / door jamb sticker recommendations and check them with a good quality tire gauge that every car owner should have. If possible they should be filled when still cold. I have a small compressor that I use in my driveway so the tires are always stone cold. You should check your tires every month or before a long trip. I'm lax myself in this regard plus its damn cold out. The 1.45 reading seems like a red herring to me--how do you know which inflating device is inaccurate? Use your own gauge. I would rather fill up the tires using my gauge (if on a trip), drive home and let the tires cool down and then check them with my own gauge again for the best accuracy. A small variance to the upside is probably better than a variance to the downside when it comes to pressure. 35/36 fronts and 39 rears sounds right. You'll need to re-check the tires once the weather warms up in the spring (if it ever arrives).
2018 640ix GT; Alpine White, Blk Nappa, Piano; M-sport, Premium (Ceramic, SIRIUS, Soft-close, Vent/Massage Comfort seats, Surround, Sunshades, Parking Ass't), Advanced Driver Ass't (Lane keep, Steering/Lane control, Cross traffic, ACC with Stop/Go), Smartphone, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i, 12 BMW 535i X-drive |
03-13-2017, 03:05 PM | #5 |
Rep 14,522
Very common issue here as several members including myself
