2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes F10 535 Eibach lowering springs
      12-10-2014, 05:01 PM   #1
EuroKar
Just installed some Eibach lowering springs on this clean F10 535.
Simple install. Nice drop with no rubbing issues.
      12-10-2014, 07:50 PM   #2
twelve535i
twelve535i's Avatar
Drives: 2015 X5 35i M Sport
It looks like a good drop, but hard to see because side views are blurry
      12-10-2014, 08:01 PM   #3
EuroKar
Thanks. It is.
Doesn't drop as low as H&R springs would.
I'll try to get some clearer pictures
      12-11-2014, 12:00 PM   #4
Jayphil
Jayphil's Avatar
63
Drives: 535I xdrive 2011 (M-SPORT)
Hi,
I am looking for a spring setup for next summer that would be a bit less agressive than the H&R. The Eibach seems to be a good candidate.
Was the 535I, Xdrive or RWD. Seems to be difficult to find teh Eibach Xrive version in USA/Canada and mostly only available through Europeen vendors...
      12-11-2014, 12:08 PM   #5
EuroKar
Originally Posted by Jayphil View Post
Hi,
This vehicle was RWD
I did a search and only could find H&R that fit your XDrive model.
If you are using the factory BMW wheels you will still have good clearance. If you have larger aftermarket wheels then the drop may be too much with H&R
      12-11-2014, 02:52 PM   #6
Jayphil
Jayphil's Avatar
63
From my research look like Eibach part number for Xdrive is either
E10-20-022-10-22_371 which drops about 30mm (1.2 inch) Front & Rear
E10-20-022-04-20_367 which drops about 30mm (1.2) front & 25mm Rear (a bit less than 1 inch).
But I have found this in UK not USA or Canada so it might not be available to us...
What was the drop claimed by by Eiback for that RWD 535I?
      12-11-2014, 02:56 PM   #7
EuroKar
Front: 1.0 in
Rear: 0.6 in
http://eibach.com/america/en/perform...ication-lookup
      12-12-2014, 09:27 AM   #8
JCat27
Drives: 2013 535i
You should shake the camera around more ...Jk
Post up some more pics when you can get some clear shots
2013 535i: BMS Intake, JB4, Megan Racing Exhaust, ER Charge Pipe, Hamann Style Diffuser & Front Lip, Carbon Spoiler, Megan Racing Coilovers, 20" Forgestar F14's & Velgen VMB8's Matte Silver, A couple other parts and other little things that I'm forgetting.
      12-12-2014, 07:13 PM   #9
EuroKar
lol
Will do
      12-23-2014, 04:40 PM   #10
Grzechos
Grzechos's Avatar
Drives: E36, E90, F80 M3, F90 M5
What wheels are those? What setup? More pictures?
      12-23-2014, 04:57 PM   #11
EuroKar
Some aftermarket brand "knock off" BMW rims.
It is a clients car of mine. I only installed the lowering springs for him.
