2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum I can't be the only one with this problem
      02-23-2018, 01:07 PM   #1
Alpine5x
Drives: Alpine F10
Angry I can't be the only one with this problem
I have a 2013 528xi and when climate control is on I hear a very faint thud noise or faint knocking noise that can be felt on the steering wheel and brake pedal.
This only occurs when the climate control is on regardless of whether engine is on or off.
The only way to stop the thudding or knocking is to turn climate off or to the coldest setting.
Anyone else affected? Can anyone weigh in on this matter?
      02-23-2018, 07:54 PM   #2
MichaelSNU
Drives: 2006 X3; 2016 Volvo XC60 T5
The same exact thing is happening to my wife's 2006 X3 with 141,000 miles... The BMW tech believes it is the "IHKA heater valve." I am not sure if this helps or is applicable to your issue.
      02-24-2018, 01:20 PM   #3
Alpine5x
Drives: Alpine F10
did you get it fixed? what was the resolution?
      02-24-2018, 01:55 PM   #4
MichaelSNU
It is going to the dealer next week for the repairs. Something around $600. I will let you know. BTW it was having that problem for about a year so I do not think it was urgent.
      02-25-2018, 10:15 PM   #5
Alpine5x
Drives: Alpine F10
Thanks bro please keep me posted with the diagnosis and report here. Anything helps!
      03-05-2018, 08:26 PM   #6
MichaelSNU
The 2006 X3 came back from the dealer and the thudding in the break peddle when the heat is on has stopped. The tech put it was the "IHKA heater valve" in the quote, but the invoice said "replace water valve." Cost: $370.78
I hope this helps.
      03-06-2018, 12:46 PM   #7
Alpine5x
Drives: Alpine F10
Yes i wonder if heater valve = water valve. I got a quote 130 for the part and 170 for repair
so more or less 300+taxes and fees so roughly about the same as you.
this helps a lot. Water valve i read on various forums is same as heater valve. I'll be doing this repair in the fall after summer time.
      03-19-2018, 09:50 AM   #8
marcmicalizzi
Drives: 2014 535i xDrive
I have the same thing as well, not sure if it's actually a problem that warrants attention or not though?
