2010 2011 BMW 5 Series Forum F10 Hard wiring a radar detector |
01-06-2015, 06:28 PM | #1 |
Rep 228
Hoping to get some advice. I search the forums and found a few answers but not any definitive ones on the best way to hard wire after market electronics to a F10.
I have a Beltronics (Escort) STI Magnum detector and I have the smart long cable for hard wiring it. any advise on where to pull the power from? Fuse box? any particular fuse? I just don't want it to throw codes and it would be nice if it shuts off once I lock/alarm it. Any advice here is really appreciated. Thanks! |
01-06-2015, 08:59 PM | #2 |
Rep 41,020
Drives: 2018 Alpina B6 650ix GC
Here is my Escort install in my F10:
http://www.bimmerfest.com/forums/sho....php?p=6112632 http://www.bimmerfest.com/forums/sho...7&postcount=10
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
01-06-2015, 09:28 PM | #3 |
Rep 1,761
I created a thread on my install. Check threads I created.
2015 BMW X5 35i M-Sport (White/Brown) - 4/16/18 (Current)
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST | 1998 Acura Integra (Black/Black) - PAST |
01-07-2015, 03:38 PM | #6 | |
Rep 228
01-07-2015, 03:52 PM | #7 |
Rep 41,020
01-10-2015, 01:19 PM | #8 |
Rep 345
I have mine mounted on the passenger side sun visor with the visor clip. The direct wire connection goes down the passenger side A pillar into the glovebox (had to pop the end cap). There is an exposed metal frame for the ground and I added a fuse tap onto fuse 48 (mini) for the power. Took a combined 10 minutes to install, and can probably be reversed in 1/2 the time. It helped that I had the trim tools and the add-a-fuse. It was around $5 from Advance Auto parts in case anyone is wondering.
Also, be careful if your passenger puts down the visor, as the radar can be pushed off it and fall. I don't have passengers in my car very often and when I do, I either take it off or warn them not to do it. I did have it on the driver side, but there were times that even with sunglasses, the sun blinds you and you need the visor. The advantage of the driver side is that I could actually see the numbers for the radar frequency, which is much harder to do if installed in the pass side. The great part about the sun visor install is that it's hardly noticeable from outside, thus lessening the chance of theft. I still have the Escort 9500ix, but I've been eying that Passport Max2. Looks pretty sweet. Last edited by marsb007; 01-10-2015 at 01:25 PM.. |
