2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum How can Code out adaptive headlights using bimmer code?
      06-20-2022, 12:46 AM   #1
automaz_
Enthusiast
automaz_'s Avatar
510
Drives: 2025 M4 Comp xDrive
Hey guys my 2012 pre lci 535 x drive was getting a good ole car wash and then all of a sudden all these light malfunctions happened. The passenger side Angel eyes are out and the driver side REAR tail lights hyper blink. The passenger side indicator hyper blinks too. I opened the headlight cap and let everything dry out and the blinkers all work properly now. However the right Angel eye turns on when I unlock the car but as soon as I start the car I get "adaptive headlight malfunction" and my passenger side Angel eyes turn off and no longer turn back on. I don't know if the tms is damaged but I am thinking that if I'm able to code OUT the adaptive headlights then my Angel eyes will turn back on.
2025 M4 Competition xDrive
IG: Automaz_
      06-20-2022, 09:27 AM   #2
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
That will not fix DRL. The module controls everything besides low/high beam. Better to isolate issue and correct. Check module, it may still be OK
      06-20-2022, 03:09 PM   #3
automaz_
Enthusiast
automaz_'s Avatar
510
Everything is now working perfectly again
However I keep getting the adaptive headlight malfunction error and cannot clear it using bimmerlink
Can anyone help me clear this code?
IG: Automaz_
      06-20-2022, 08:54 PM   #4
culto
Drives: E90, F10, F30 and F48
You need to change your headlight control module. I had similar issues after my control module was damaged by water. I bought a used one on eBay and changed it yesterday. Here's a link to a video I used:
automaz_510.00
      06-20-2022, 11:05 PM   #5
automaz_
Enthusiast
automaz_'s Avatar
510
How much did you pay for the module?
Thanks for the video link
IG: Automaz_
      06-21-2022, 08:33 AM   #6
automaz_
Enthusiast
automaz_'s Avatar
510
It's kind of ridiculous that everything on my car works perfectly fine but this error will not go away. ADAPTIVE HEADLIGHT MALFUNCTION is the worth error possible created lol
IG: Automaz_
      06-21-2022, 08:34 AM   #7
automaz_
Enthusiast
automaz_'s Avatar
510
Did you have to do any coding after installing?
IG: Automaz_
      06-21-2022, 06:35 PM   #8
culto
I was able to find one that was from the same model and year as my car on eBay. It was inexpensive and I decided to take a chance (glad I did). No coding was needed.
automaz_510.00
      06-22-2022, 11:45 AM   #9
automaz_
Enthusiast
automaz_'s Avatar
510
BimmerCode - how to code out adaptive headlights
I've done so much research but can't seem to find the answer for F10. I know it can be done as people have commenting saying online that they've done it. Does anyone know how to code out adaptive headlights for the F10 using bimmercode?
IG: Automaz_
      06-22-2022, 07:09 PM   #10
automaz_
Enthusiast
automaz_'s Avatar
510
I figured out the solution
After many days of trying to code this thing. It was 100% possible to code out the infamous "ADAPTIVE HEADLIGHT MALFUNCTION" using bimmer code for the F10
Go to footwell module and expert mode and select FRM 3400 and change the following three sections
ALC_AFS_ENABLE > nicht aktiv
AHL_ENABLE > nicht aktiv
LWR_AHL_TYP > ohne_lwr
No more Adaptive headlight malfunction error code
IG: Automaz_
      07-17-2022, 09:01 AM   #11
Matgsand
Drives: BMW F1O 520d N47
Good to know for future reference, thank you
automaz_510.00
      07-17-2022, 04:24 PM   #12
Hoa
When doing this, you will loose the adaptive feature which matters when driving at night.
It looks like your TMS module is bad. TMS module is only about $50 on eBay.
      07-17-2022, 04:54 PM   #13
automaz_
Enthusiast
automaz_'s Avatar
510
Yeah otherwise the tms module needs to get coded. I ended up getting a new tms module but I will be doing custom headlights anyways though so will have to disable adaptive headlight
IG: Automaz_
      02-22-2023, 12:45 PM   #14
DarkgraphiteNYC
DarkgraphiteNYC's Avatar
27
Drives: '11 535xi, '11 328xi (ret)
Thanks so much for providing this code! I've been dealing with this error message for longer than I can remember and just came across your fix. Much appreciated!!
      02-23-2023, 06:58 AM   #15
SteveMD
SteveMD's Avatar
198
Drives: 2016 F10 535i MSport
Just a word of warning, the LCIs use a different sized module - it has the red gasket and three screw holes. That one DOES need coding. Pre LCI module is slightly smaller and just has two screw holes.
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      03-19-2023, 02:02 PM   #16
Mnotfeelingit
Mnotfeelingit's Avatar
19
Drives: 2017 750i M Sport
It’s probably just worth buying a new one from an aftermarket shop considering you’ve had the car for awhile, it sucks these F10’s are prone to this type of headlight damage.
Car washes, rain or just condensation really destroy them.
      03-25-2023, 06:27 PM   #17
dnorfolk
Drives: BMW 528i
Did you code it yourself? I'm in the same boat--replaced the module but now need to program it.
      04-29-2023, 10:59 AM   #18
EVO_F10
Drives: BMW 535i
Thanks, that's super helpful.
      03-22-2024, 10:36 PM   #19
asianguccimane1$
Drives: 2015 bmw 550i, 2010 bmw m6
Does anyone know if this is the same procedure for the lci Xenon’s with adaptive lighting?
