2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Rear end skipping on hard accleration
      01-26-2018, 08:14 PM   #1
jackliu0527
Drives: BMW 650iXdrive GC
I have a F06 650 Xdrive, on hard acceleration i feel what i think is rear tires (or somewhere in the rear) skipping a little bit, it is most prominent during 1st 2nd and 3rd gear hard acceleration from a dead stop of slow speed, I dont hear anything noise from the back end or strange sound, and my car stays perfectly straight and not feel like i am going to loose the rear end anytime soon, just feels a bit skippy
My car mechanic friend told me based on what i have said sounds like the rear diff might be on its way out of the door
My actually mechanic who does work on my car says could be my rear brakes since they are wearing out unevenly
Both made the assumptions without looking at my car, I was wondering if anyone here have experience similar events and provide some thought?
*I forgot to mention I am currently running bridgestone blizzak lm-32s winter tire cause its cold up here, however I didnt have this problem before with the same tire setup
      01-29-2018, 10:26 AM   #2
BMW550AD
Drives: 2014 BMW 550i
2014 BMW 550i  [0.00]
2014 550i here and I have experienced the same problem. Almost like your hitting a tiny speed bump under the rear wheels at heavy acceleration. Would love to hear if anyone else has had this happen and if I should be concerned it's a larger issue.
      01-29-2018, 12:03 PM   #3
SchillerM
Drives: 11' 550i, '00 M5, '11 E90 335i
Does the traction light come on? Only shipping I feel is when the rears are trying to spin..
      01-29-2018, 02:17 PM   #4
Dcm1952
Dcm1952's Avatar
Drives: '14 535i Msport, 99 M Roadster
Really sounds like the traction control working to me. Turn off traction control and accelerate hard. Should get wheel spin only.
      01-29-2018, 05:49 PM   #5
Had that happen on a previous RWD car. The only thing I can think of is I hit a patch of oil on the wet road as I saw nothing.
      01-29-2018, 06:52 PM   #6
jackliu0527
traction light does not come on, also tried in DSC off, same results
for me it didnt feel like i was hitting tiny speed bumps, just feels like rear is skipping alittle
      01-30-2018, 12:53 PM   #7
wrecked2001
Drives: 2013 535i Msport/Imperial Blue
Check the rear bushing on the Diff and the rear Guibo
      01-30-2018, 01:40 PM   #8
Stück
Stück's Avatar
What you are experiencing is likely wheel hop. Differential bushing torn is a possibility but I've not seen that cause it in on itself.
Weak rear shocks, dissimilar road surfaces, even adjusting tire pressures and make or break this behavior.
At the end of the day wheel hop is a rather common issue with high powered independent rear suspension cars.
      02-05-2018, 12:14 AM   #9
addy27
Drives: F10 550i
OK, surprisingly enough, when I first got my car, upon hard acceleration from stop, I felt a skip/bump too. Took the car in and they said everything on the rear end looks good but one of my engine mount up front was shot which they said caused the whole setup to move such that it presented itself as something in the back. Once they replaced the engine mount. no such sound/skipping. Maybe check the engine mounts?
      02-15-2018, 10:51 AM   #10
Tallest
Tallest's Avatar
1301
Drives: 911
2011 911  [10.00]
xdrive here, same issue, worse on 20s, easier on 18s. suspecting its xdrive and transfer casing but - all checks turned out negative results. no clue also why this is happening... I will mount 19s in next summer with fresh michelins. If this persists ill go back to dealer. I also thought it was DCS but lights arent flashing so...
F30.F11.E86.E90.E90.E36
      02-27-2018, 01:43 PM   #11
Shieldze1025
Keepin' America Free
Shieldze1025's Avatar
Drives: F10 535i
It's just wheel hop, the car is trying to spin your tires but not quite powerful enough. My last car did the same thing and my 535 does it too.
As Stuck mentioned above, a lot of things contribute to it, but the smallest cracks or bumps in the road will cause this. Make sure your DSC is completely off as well, hold the button down for 5 seconds to turn it completely off.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough"
-Mario Andretti
      03-13-2018, 02:52 PM   #12
jackliu0527
So the problem went away after I swapped from my Blizzaks back to Summers... so I guess it was the winter tires not enough grip -.-
      04-02-2018, 07:42 PM   #13
Shieldze1025
Drives: F10 535i
Sounds about right, esp when you consider winter temperatures.
Hope you're enjoying the full power with good tires now
-Mario Andretti
      04-04-2018, 01:18 AM   #14
Tallest
Tallest's Avatar
1301
Drives: 911
2011 911  [10.00]
About to go to summers also and will report if the issue went away - or not.
FWIW on all my previous RWD BMWs (5 I think) Ive never experienced this hop but on xdrive it is present. My previous summer setup also exhibited it, but there the issue was for sure crap tyres contributing. Lets see how she does now...
      04-04-2018, 02:03 PM   #15
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
I've had it happen with my RWD 550i. Theres a combination of things that can cause this. Temp, weather, tires, bushings, surface... etc.
Bad shocks deff will cause it.
