2010 2011 BMW 5 Series Forum F10 using E85 with jb plus on n63tu engine |
03-09-2016, 12:14 AM | #1 |
Rep 346
i am using the jb plus mod with default setting at pump 91 oct gas (non ethanol added) on my 2013 650xi.
i used to have a 335i with n54 engine and i could mix e85 and 91 to get e30 and then run race map on cobb tune. so if i mix e85 with 91 octane to obtain e30 can i turn the dial up from default and see improvement? is there a way to datalog the car for timing issues while running e85 mix? can BT cable from burger tuning be used for datalogging? |
03-09-2016, 10:32 AM | #2 |
Dream crusher
984
Rep 2,421
I've used e85 without a tune, with a jb+, JB4 and on several flash tunes. You should be able to run about 6gallons on a good tune. I would start with 3 gallons and see how your car likes it. I've experimented with going over 6 gallons and my car didn't like so I drove cautiously and put more 91 on top of it to lower the rating. Just remember your car mpg is about to drop.
IG: @bmwdoubles |
03-09-2016, 11:38 PM | #3 |
Rep 346
got reply from bms they said e85 use is not supported for n63tu platform.
logging via bt cable can be done but is very limited and recommended to contact bav tech directly to find out. |
03-10-2016, 07:29 AM | #4 |
Rep 14,521
Any long term effects on the motor using E85 all the time?
03-10-2016, 07:38 AM | #5 | |
Rep 844
As stated above though, your car is NOT a flex fuel car, so it will only be able to adjust for air fuel ratio based on fuel trims and O2 sensor readings, so don't expect to just toss a few gallons in and be able to feel the difference immediately, but the more you drive it, the better it will feel, especially if you can keep a consistent mix for a few tanks. As others have said, E85 has about 65% the energy of gasoline, so it will burn quite a bit more fuel to achieve the same energy (expect a 10-15% reduction in fuel economy for a 30% mix), but the pay off is the cooling ability of E85 which keeps combustion temps and air charge temps down as well as reduces the possibility of detonation. Of course the best way for a non flex fuel car is still either using Torco additive, or actual race fuel. With race fuel not being available everywhere, as well as expensive for either enough 100 octane to make a good 96 mix, or running straight 100, you can get Torco relatively cheap in bulk (or individual cans if you want to leave them in the trunk and only use when needed) and that will allow your vehicle to operate on the same fueling as it would on normal pump gas, but allow for the ability safelty handle more boost and timing.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
03-10-2016, 07:48 AM | #6 |
Rep 844
Not since the 90s... just about every car is "alcohol safe" now, more so since almost every pump fuel has ethanol mixed in it. There were horror stories about people using it on older vehicles as the cleaning ability of E85 (it is alcohol after all) would causes chunks of garbage to come off the valves and combustion area, but ive really yet to see it happen beyond urban myths or people "who know a guy". On top of that, with being direct injection, there really isn't a chance for the fuel to go near anything besides the combustion chamber where as with other vehicles, it comes into the intake manifold through standard injectors and cleans the cylinder heads and intake manifold on its way in.
I ran it for 2 years issue free in my Mustang (a non E85 car I tuned to run it), but im also quite good with automotive and tuning, so I know what to look for before it happens. Many people jumped on the train with little to no experience and had issues, then when other uneducated people jumped in with their theories, it just became a rumor mill of uneducated guesses and fingers being pointed. There are downsides to running it as a replacement for race gas (poor mans race fuel), but also many upsides when used correctly.
03-10-2016, 08:27 AM | #7 |
Dream crusher
984
Rep 2,421
FenixMike excellent breakdown of e85 adapting over time and safe blending to reduce knock in high heat situations.
IG: @bmwdoubles |
03-10-2016, 01:49 PM | #8 | |
Rep 14,521
Great info on the E85
03-10-2016, 07:43 PM | #9 | |
1506
Rep 676
Drives: '17 F31 340xi US Spec
Time to switch to a re-flash tune I think. We usually run 6 gallons of E85 on our test car, '15 550i and results are phenomenal amount of thrust...And im saying thrust since the car feel like a jet during a take-off. Puts you in the seat and only lets go once you release the throttle |
03-10-2016, 08:36 PM | #10 |
Rep 1,300
I have used E85 on all my ECU tunes/flashes and the power is improved and smoother. Deff feel it.
I would Deff stay under the 35-40% mark for E85. Just pour and be happy! The car takes it without issues. Trust me I know, I'm the World record holder for the N63TU baby! |
03-10-2016, 10:56 PM | #11 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
03-10-2016, 11:07 PM | #12 | |
1506
Rep 676
I personally like to tune my cars for e40 (around 6 gallons on f10). The reason behind it is that this mix, 40% ethanol, is the highest ethanol percentage we like to tune and still be backwards compatible with 100% pump gas. A tune designed for over 40% ethanol mix seems to not be too happy when 100% pump gas gets randomly dumped in. With e40 mix, the mix produces around 95octane result and this is more then sufficient for a daily driven vehicle. Add this to a richer wot mixture and you get a very good result. And records are there to be broken for sure. Soon enough a new world's fastest n63tu will be built. At this point we are at 500whp/550wtrq at which point stock 2.5bar MAPs started to be the limiting factor. Now with 3.5 bar and our new torque managment, numbers should be a bit higher Last edited by MissionPerformance; 03-10-2016 at 11:20 PM.. |
03-13-2016, 01:13 AM | #13 | |
Rep 346
how were you able to datalog your car and detect knock? i will try adding 3-4 gallons of e85 to 91 non ethanol gas it will give 14-18% ethanol blend and raise octane rating to 93-94. |
03-13-2016, 01:16 AM | #14 | |
Rep 346
i think dinan has the ability to do that but thats too expensive and restrictive in terms of gains. |
03-13-2016, 01:18 AM | #15 | |
Rep 346
03-13-2016, 01:20 AM | #16 | |
Rep 346
03-13-2016, 01:29 AM | #17 |
1506
Rep 676
The sensors are user replaceable on all engines, tho the job is pretty difficult on n63 and s63. For those two engines, we recommend a professional installation.
Yes, these sensors can be adjusted to work with stage 1 tune on all engines, tho it's not necessary as they only get maxed out with DP and high torque numbers. |
03-13-2016, 07:12 PM | #18 | ||
Rep 1,300
03-13-2016, 08:57 PM | #19 |
Rep 91
Subscribed.
2007 M5, 6 speed, Silver Gray Metallic, Full Black Merino Leather, Brushed Ti Trim, HUD, Active M Comfort Seats/Heated & Cooled, Navi, Premium Sound, HK L7, Active Steering/Suspension, PDC, Rear & Side Sunshades, Adaptive Bi-Xenon, Voice Command, Custom S/W, Passport 9500ci w/jammers, Dinan High Flow Air Mass Meter/Intakes, CF Front Strut Brace, S1 Suspension & Free Flow Exhaust, Evolve S2 Tune
03-14-2016, 02:02 AM | #20 |
Rep 346
03-14-2016, 10:07 AM | #21 | |
Dream crusher
984
Rep 2,421
There are several apps for data logging. Dash commander, engine link and eobd-facile. Those apps also use the elm327. EngineLink has a nice e85 monitoring graph.
IG: @bmwdoubles |
03-15-2016, 03:06 PM | #22 |
Rep 844
I have the Bavarian Technic scanner, but I detect knock by audible knock...
