2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Driver restraint system malfunction
      01-14-2015, 03:35 PM   #1
VodkaOne
France
Drives: BMW 530d xDrive F11 '12
Red face Driver restraint system malfunction
Hi,
Got this warning today on my Dec. 2011 530d xDrive F11: Driver restraint system malfunction.
Wheel buttons don't work anymore and turning the wheel makes some strange noise like repetitive 'clic' sounds that come from behind the wheel.
It looks like it's a cable or connector that got disconnected from behind the wheel and that it's hampering / preventing the free movement of the wheel.
Seen this before ? Can my wife still drive the car safely until we get this fixed at the dealer ?
I called the assistance this evening but they didn't call back.
      01-14-2015, 03:41 PM   #2
geminiys
Drives: 2013, 535XI & 2005 M3
Most likely your slip-ring (item that provides connectivity between Air Bag and the rest of the harness while steering wheel can still turn) either got disconnected or wires broke off. You do need to take it to a dealer to have it checked and replaced defective parts.
I wouldn't drive the car as damaged items may lock your steering wheel during driving. Have it towed to a dealer.
The least you can do if you are mechanically inclined is to check it yourself. Pop Air Bag out and take a look. Even if you fix it yourself dealer needs to be involved to have the code cleared.
2013, 535 XDrive, 112k miles
1997, 328is, 335k miles - Retired
1998, ML320, 200k miles - Sold
2018, Q5, 100 miles
2005, XC70 AWD, 160k miles
      05-08-2016, 02:10 AM   #3
alsohey
Drives: F11
Same problem
Have got the same error today, with the same click sounds. What was wrong with yours??
AlsoHey
      10-30-2016, 05:41 PM   #4
Bigthistle
Drives: 2014 640xi GC
Driver restraint malfunction
Did anyone figure out what was wrong?
      01-03-2017, 10:31 PM   #5
Brandon6127C
Brandon6127C's Avatar
11
Drives: 2011 BMW 535i M sport
Anyone ever get this fixed. Out of no where mine did the same exact thing tonight.
      01-04-2017, 09:23 AM   #6
Bbb34
Drives: '11 535i 6sp. DHP/RWD
There are two ways I'm aware that this can happen, there might be others.
Driver or passenger seat getting wet and seat mat sensor confuses the system, warning will likely go away after the seat dries.
Cleaning up your car and moving your seats every way possible (too far back/forward or too high/low) might require "re-calibration/reset" at the dealer (silly I know, but this actually happened to me).
Hope this helps.
      01-04-2017, 02:55 PM   #7
Brandon6127C
11
I definitely haven't been cleaning my car. It was sitting in my garage for a couple hours (4) then I went to store and it did it out of know where. I'll try to find some sort of seat recalibration.
What's the clicking in steering wheel then if it's from seat?
      01-05-2017, 04:48 PM   #8
Brandon6127C
11
Today the clicking sound had a large pop when I was turning to park in a parking spot. Now none of my steering wheel controls work. Paddle shifters either.
      01-10-2017, 04:25 PM   #9
Brandon6127C
11
Bad steering angle sensor. $555 for part
      03-13-2017, 01:58 PM   #10
hanadul
Uncle J
Drives: 2011 535i F10
I have 2011 F10/535i rear drive and I have exact same issue.
Anyone fugure out what's going on?
      03-13-2017, 04:14 PM   #11
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
Could also be a fuse, the same one that is used for the vanity mirror lights. It's a common issue.
      05-19-2017, 12:45 PM   #12
Arumeen
Drives: 520d
Hi all
I had exactly same problem today in my 520d. How did you guys sorted this please, what's the best and efficient way to go about it? Thank you all in advance.
      07-22-2017, 03:54 PM   #13
hanadul
Uncle J
Slip ring issue but have to replace whole unit
Not sure why BMW made it like this.
BMW put easily break part into the expensive unit and ISTA informed " it must be replaced whole unit".
Slip ring is flexible flat ribbon cable located inside of SZL module (steering column switch module) and provide power & signals to air bag, horn and other function switches on the steering wheel.
E serise has seperate slip ring module and can easily replace it but F serise has one whole unit and you have to replace whole SZL module ($550) + Labor + Reprograming fee.
You can re-solder cable if you can but personally I couldn't do that.
I'm pretty sure most of F10 slip ring will be break within 3-7 years because it is a moving part and made by cheap ribbon cable.
I checked mine and found both cables (it has 2 ribbon cables) are broken into 6 parts (see picture.).
      07-22-2017, 06:42 PM   #14
MavRick
MavRick's Avatar
688
Drives: My Wife's M
Hope this helps.
Left my sunroof open and a sudden downpour drenched my interior. When I started the car....got that same warning. Left the sunroof/windows open the next day...cleared right up
      12-16-2018, 05:20 PM   #15
Boulder Bill
Boulder Bill's Avatar
Drives: 2018 Porsche Cayman GTS
Just had this happen and the same warning signal/clicking noise occurred.
Took it by the dealer. The preliminary diagnosis is broken clock spring, whatever the hell that is.
Dealer said safe to drive, except the airbag has now been disabled.
I'll post more when I take it in for service.
Anyone else been all the way down this road?
Bill
2013 F10 550i | 6 Speed Manual | M Sport Package | Carbon Black | Oyster & Black Nappa | Dynamic Handling w/Dynamic Damper Control | Executive Package (Comfort Access - Soft Close - HUD) | B&O Sound | Luxury Seating & Heated Seats
(retired: 2002 E39 540i | 6 Speed Manual)
      12-17-2018, 05:25 PM   #16
Boulder Bill
For anyone happening upon this thread, the clock spring is considered by Route 66 to be part of the restraint system, and not covered.
I think they are right.
