04-29-2023, 05:43 AM | #1 |
Rep 30
Drives: BMW F11 535i MSport
Suspension
I own a 535i Touring (F11) 58,000 miles, recently I have had my suspension (front left shock blew out) as well as my Air Pump stop working. On my e46 my suspension only needed changing at 100,000 miles.
My question: how many of you had to change 1 or more of your shocks + at what mileage?
535i F11 Msport, Masata IC, Masata Charge Pipe, Masata Turbo to IC pipe, BMS Air Intake, K+N Oil Filter, Catless DP, Stage 2.5, Brembo Brakes + EBC yellow pads.
04-29-2023, 10:19 AM | #2 | |
Rep 252
05-06-2023, 05:28 PM | #3 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
How long your shocks last depend on the quality of your roads, how much weight you put in your car. If you modified your suspension (lowering or lifting), especially lowering blows shocks. If you put on larger rims, and etc.
So in other words how long your shocks last depend on a lot of factors. If you don't lower it, don't use low profile tires, keep them inflated properly, have smooth roads. They last a long time. I think 30k-100K miles is pretty normal. They also wear out gradually so most people can't tell they need to replace them, until they are bouncing down the highway. |
