01-10-2016, 10:15 AM | #1 |
Rep 767
Water drainage
Hey guys could you tell me where all the drainage plugs are on the F10 so I can check them out and make sure none are clogged. Noticed some water inside the cabin today :
01-10-2016, 10:40 AM | #2 |
Rep 74
I sure do miss having gurus like the old E39 boards used to have. You could get answers to questions like this in a nano second. I to am interested. How about a list of SIB's?
01-10-2016, 10:51 AM | #3 | |
Rep 767
01-10-2016, 10:57 AM | #4 |
Rep 29,202
Water in cabin might be caused by a failty water seal inside the door.
01-10-2016, 11:10 AM | #6 |
Rep 74
My above post was not helpful at all, sorry. What I know from an E39 and an E83 is to check the following.
Sunroof drains. Open sunroof and carefully poor water into the channel that leads to the front corner and see if and where it comes out. Do both sides then find the tube end where the water is coming from and mess around with the end to see if there is debris there. Take a length of trimmer cord from a weed eater and run up as far as you can. You probably can only get to the top of the A pillar where there probably is a 90 degree elbow. Try it from the top also. The rears are a big pain but to see if they are open pour water as far back in the same channel as you can. You may have to have the nose up a bit to get the water to drain in that direction. I have never had them blocked but I also have never been able to find where they dump out, it seems to be above the inner fender liner on the older models. Lift hood and open up the housing for the cabin air filter which used to be right under the windshield. Take the filter out and see where the drains are. I know over the years they enlarged these but they may still have a rubber flapper at the bottom where the water exits. Due to all the crap that gets in here they could be stopped up causing water to come in through the firewall somewhere which could cause catastrophic problems with the fuse box in the glove compartment. The one common denominator I have found in 3 BMW's is that the door membranes can and have leaked. If you ever had any door dent removal done or any work done that required going into the doors this very well could be the problem. This membrane is or used to be attached using butyl tape and it is a you know what to get sealed properly. On one car the BMW dealer tried 3 times. I finally had my body shop guy do it successfully. Open your doors and lay down on the ground and look up under the bottom of them. There are several drains there as well. Using a flashlight see if the are blocked, Stick something with a small bend in the end and see if you can pull anything out. Trying to determine where the water is coming in from where the floor is wet might help zero in on the culprit. But there are only a number of ways it can get in. Make sure your A piller is not damp (inside the car). Check the rear trunk area also. Sorry I can't be more specific but I have only had my 535 3 days now and with a back issue I don't feel like going out there and crawling around. Let me know what you find though. |
01-10-2016, 12:51 PM | #7 |
Rep 36
I had a leak problem a few months ago--after a lot of rain, the floor in the rear footwells would be soaking wet and water would splash out when I opened the rear doors. I couldn't see exactly what was causing this, but the dealer wound up replacing the following parts:
"51-48-7-366-707 Sound Insulating Door Rear" "51-48-7-366-708 Sound Insulating Door Rear" The dealer described the work as replacing the rear door vapor barriers. I think you would have to take the doors apart to do this, though. Good luck. |
01-10-2016, 12:58 PM | #8 | |
Rep 74
These are the membranes I was referring to. And, yes you have to get into your doors however you need new tape and or barriers if yours are torn, you have to clean off all the old goo and apply new butyl tape. It is not easy. If that is what it is pay a body shop $50 bucks to do it if you have one you trust. Getting a proper seal is not easy based upon how many times I have had to have it redone to get it right. I would bet this is what the issue is since it is in the rear footwell. Unless the drain tube for one of the rear drains has separated. I have heard of them freezing and coming apart a long time ago. It could possibly be rear sunroof drains but there should be water in the battery area of the trunk. Suck out what water you can with a shop vac. If you are under warranty let the dealer fix it and dry your car out. Last edited by 535MSport; 01-10-2016 at 01:34 PM.. |
